September 14, 2005, 08:14 |
i want to use probe command in
i want to use probe command in the filter ,but it is gray ,what is the reason!
September 14, 2005, 09:30 |
I don't know how to work with
Billy
Rep Power: 17 |
I don't know how to work with probe either. But if you select pick first then probe becomes active.
September 14, 2005, 10:00 |
I just had the same pro
Fabian Braennstroem
Rep Power: 19 |
I just had the same problem with ensight-formated data. I had multiple parts, so I had to 'ExtractParts', select 'solid...'. Then 'probe' was available; but I am not sure if it works for you. Greetings! Fabian |
September 14, 2005, 10:33 |
Hi all,
i'm also mew her
Hi all,
i'm also mew here but I will try helping a little bit!!! As far as I understood, most functions of the filter menu work in dependency to others. That is, there are some filters which have to be firstly applied in order to enable the usage of others. Like in the cavity example in the user guide where a "Cut" has to be applied before getting "contour" to work. What actually makes a lot of sence... Hope that helped. Regards, v.p. |
September 15, 2005, 06:02 |
thank you very much!
then ho
then how to probe the data on a curve |
November 29, 2006, 23:53 |
G'day,
I have worked it out
G'day,
I have worked it out, First, you have to go 'Extract Parts" in Filter menu, then select 'Internal flows' only, press 'Accept'. 'Probe' in 'Filter' menu should came up. fl!c |
November 30, 2006, 03:22 |
Hi ztdep,
So far, the only
Vincent RIVOLA
Rep Power: 18 |
Hi ztdep,
So far, the only way I found to make a probe on a curve was to create the curve with another software. Take the file with the points defining this curve and do a sample (in FoamX for instance) using this points. Sorry but I didn't find an easier way. But is someone else did, I would be pleased to know how. Vincent |
Probe for X or Y velocity | msrinath80 | OpenFOAM Running, Solving & CFD | 29 | July 22, 2015 17:46 |
Probe problem | nzy102 | OpenFOAM Running, Solving & CFD | 1 | April 14, 2008 01:16 |
Probe or something else to monitor | hoerl | OpenFOAM Running, Solving & CFD | 2 | January 15, 2007 06:04 |
probe | hydrogen | CFX | 2 | May 22, 2006 11:59 |
problem with probe | Yolanda | CFX | 0 | May 17, 2006 06:27 |
