choice of fvSchemes for high-aspect-ratio grid |
July 15, 2010, 10:51 |
Stefan Herbert
Rep Power: 17 |
Hi all,
I'm trying to solve a compressible case with very big dimensions (about 5mx10mx20m) with high velocities at the same time (about 200 m/s). In order to get acceptable y+ values I had to apply a grid with boundary layers. Now I have cells with very high aspect ratio (>1000). Also there are some but not too strong non-orthogonal cells (<90) To initialize the flow field I started a incompressible calculation with constant density. It looks not too bad, but as soon as I want to solve temperature equation (just as passive scalar) I get temperatures between 0 and 10,000 K (should be 300-700 K)! I think this could be fought with using other divSchemes, but I've tried a lot (upwind, linear, linearUpwind with face or cellLimited ...) - without any success. CFX produced good results, but who knows what is happening in there ). Any suggestion what I can try? Regards, Stefan |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 12:01 |
Aspect Ratio at high turbulent and swirled flows | zago | FLUENT | 0 | May 19, 2004 02:37 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
grid aspect ratio and skew | Darcy | CFX | 2 | March 10, 2001 01:52 |
