Smagorinsky model
Old   June 22, 2006, 06:29
Default I ran a LES calculation using
Sylvain
sylvain91 is on a distinguished road
I ran a LES calculation using the Smagorinsky model and I was suprised to see that no post data files existed for k. I had a look at the code and apparently in this turbulent model the subgrid scale turbulent energy is of course calculated and normally returned. I know some data can be added using PostProcessing from FoamUtilities but I could not figure out where k was. If someone knows how to get it?
Moreover from the code I doubt about the function which returns k in Smagorinsky.H: the square of delta and deviatoric component of D.
Description
<pre>
The Isochoric Smagorinsky Model
Algebraic eddy viscosity SGS model founded on the assumption that
local equilibrium prevails, hence
B = 2/3*k*I - 2*nuEff*dev(D)
where
D = symm(grad(U));
k = (2*ck/ce)*delta^2*||D||^2
nuSgs = ck*sqrt(k)*delta
nuEff = nuSgs + nu
</pre>
SourceFiles
Smagorinsky.C
Farther in Smagorinsky.H:
//- Return SGS kinetic energy
// calculated from the given velocity gradient
tmp<volscalarfield> k(const tmp<voltensorfield>& gradU) const
return (2.0*ck_/ce_)*sqr(delta())*magSqr(dev(symm(gradU)));
If someone could help me telling me what he thinks about it? Perhaps I did not analyse the code correctly? Thanks
sylvain91 is offline   Reply With Quote
LES-Smagorinsky model CFDUSERIN CFX 5 August 28, 2008 00:43
Smagorinsky model and Sij terms James Main CFD Forum 3 December 7, 2004 10:20
Dynamic Smagorinsky Model Andrew Main CFD Forum 1 November 30, 2004 00:52
Smagorinsky Sub-grid Model Craig Johansen CFX 1 October 13, 2004 03:10
Dynamic Smagorinsky model Tim Main CFD Forum 7 May 29, 2002 07:37
