Problems starting new case interFoam
Old   October 8, 2005, 17:00
Default I get the following error star
Billy
billy is on a distinguished road
I get the following error starting a new case with interFoam:
Mean and max Courant Numbers = 0 0
deltaT = 0.002
Time = 0.002
Liquid phase volume fraction = 0.25 Min(gamma) = 0 Max(gamma) = 1
--> FOAM FATAL ERROR : LHS and RHS of - have different dimensions
dimensions : [0 -2 0 0 0 0 0] - [1 -2 -2 0 0 0 0]
From function operator-(const dimensionSet& ds1, const dimensionSet& ds2)
in file dimensionSet/dimensionSet.C at line 375.
FOAM aborting
Aborted
Does anyone know what is wrong?
billy is offline   Reply With Quote
Old   October 10, 2005, 09:58
Default I discovered the problem. Apar
Billy
I discovered the problem. Aparently when you initiate a new interFoam case (not a clone case), the dimensions set in the transportProperties file are not correct and you have to edit the file because FoamX does not allow changing dimensions.
I think version 1.1 didn't have this problem. In this version you also have to set the div schemes since they are not set by default.
Old   October 10, 2005, 13:54
Default Hi Billy, if you think this
Mattijs Janssens
mattijs is on a distinguished road
Hi Billy,
if you think this is a bug can you report it in the OpenFOAM-bugs section? Please specify which constant in the transportProperties is wrong etc. See also the bug template.
thanks
mattijs is offline   Reply With Quote
Old   June 21, 2006, 10:18
Default Hi Billy, I also have the
Guoxiang
liugx212 is on a distinguished road
Hi Billy,
I also have the same problem when I tried a new solver for CO2 concetration model. So I put my error and solver here. Could you please help me see and give some advice?
Thanks in advance.
my variables and dimensions:
nu (viscosity): kg/s*m
mu (Kinematic viscosity, thermal diffusivity, mass diffusivity): m^2/s,
pd (pressure): N/m^2 = (kg/(m/s^2))/m^2 = kg*s^2/m^3
rho (density): kg/m^3
rhoinj (injection): kg/s
resist (permeability): m^2
D (diffusion): m^2/s
Porous (porosity): constant
gh (gravity): m/s^2
C (concentration): kg/m^3
U (velocity): m/s
The error:
dimensions : [1 -3 2 0 0 0 0] - [1 -1 -2 0 0 0 0]
FOAM aborting
Aborted
My solver linking:
http://www.cfd-online.com/OpenFOAM_D...tml?1150814110
liugx212 is offline   Reply With Quote
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
Runing InterFoam for 3 D damBreak case Patch issue nishant_hull OpenFOAM Running, Solving & CFD 5 February 18, 2009 00:32
Modifying a mesh starting from case file Ale FLUENT 2 September 16, 2008 12:10
FoamX refuses to open an interFoam tutorial case vrecha OpenFOAM Pre-Processing 5 March 12, 2008 12:36
Problem starting a tutorial case alank OpenFOAM Installation 1 December 12, 2006 16:50
