June 9, 2006, 16:52 |
In order to make sure I
Greg Zink
Rep Power: 17 |
In order to make sure I'm running OpenFoam correctly, I am running simpleFoam for a straight pipe with a small pressure differential that should induce a constant velocity through the pipe. I use pressureInlet and pressureOutlet to specify the pressures on either end of the pipe and initialize the internal flow to the velocity I expect from Bernoulli. What I keep seeing is that the velocity is constant through the pipe, but the magnitude just keeps rising with each iteration, and never converges. I can run this case in Fluent, and it converges very quickly. Does anyone have any idea why the velocity field would increase in this way? Greg Z. |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 05:35 |
which pipe has the biggest velocity? | Song | CFX | 1 | December 26, 2008 12:44 |
Temperature blowup for with 6-DOF falling object | Andrew Wick | FLUENT | 3 | October 16, 2005 15:56 |
SimpleFoam for laminar flow | hsing | OpenFOAM Running, Solving & CFD | 3 | April 14, 2005 14:39 |
Velocity and turbulence measurements for a pipe | John Grimm | Main CFD Forum | 2 | January 29, 2002 12:37 |
