October 21, 2005, 10:40 |
Consider the movingCone case w
Frank Bos
Rep Power: 18 |
Consider the movingCone case with the solver icoFoamAutoMotion.
When using the second order CrankNicholson time integration I get an error message after the first mesh update. FOAM FATAL IO ERROR : attempt to read beyond EOF From function ITstream::read(token& t) in file db/IOstreams/Tstreams/ITread.C at line 70. Later I also tried this scheme in the cavity problems, but with no succes. Is someone actually using this scheme, or am I doing something wrong. Frank
Frank Bos |
October 21, 2005, 10:47 |
There has been a change in the
Hrvoje Jasak
Rep Power: 33 |
There has been a change in the format that is not reflected in the config files. Add 0.5 after CrankNicholson (now the factor is run-time selectable):
ddtSchemes { default CrankNicholson 0.5; } Enjoy, Hrv
May 21, 2006, 13:07 |
shouldn't be CrankNicholson 1?
Maka Mohu
Rep Power: 18 |
in the user guide: 4.4.6 Time schemeshttp://www.opencfd.co.uk/openfoam/do...#x20-1050004.4 it says: There is an off-centering coefficient y with the CrankNicholson scheme that blends it with the the Euler scheme. A coefficient of y = 1 corresponds to pure CrankNicholson and and y = 0 corresponds to pure Euler. The blending coefficient can help to improve stability in cases where pure CrankNicholson are unstable. best regards, Maka |
May 22, 2006, 07:01 |
Sorry, I don't understand. Wha
Mattijs Janssens
Rep Power: 26 |
Sorry, I don't understand. What shouldn't be 1?
(I only see some duplicate 'the the' and 'and and' in that section) |
May 22, 2006, 09:46 |
I mean that the previous messa
Maka Mohu
Rep Power: 18 |
I mean that the previous message seemed to suggest that: a pure CrankNicholson scheme is applied in OpenFOAM by setting:
ddtSchemes { default CrankNicholson 0.5; } while the help in the user guide seems to says that it is: ddtSchemes { default CrankNicholson 1; } which is right? Many thanks, Maka |
May 22, 2006, 21:00 |
You should be able to find thi
Hrvoje Jasak
Rep Power: 33 |
You should be able to find this out by looking at the source code:
/finiteVolume/ddtSchemes/CrankNicholsonDdtScheme/CrankNicholsonDdtScheme.H //- Off-centering coefficient, 1 -> CN, less than one blends with EI scalar ocCoeff_; Need I say more? :-) Hrv
May 23, 2006, 03:21 |
So a factor of 1 corresponds t
Frank Bos
Rep Power: 18 |
So a factor of 1 corresponds to fully second order Crank-Nicholson? I thought it should be 0.5?
Is this changed in OpenFOAM version 1.3 Frank
Frank Bos |
May 23, 2006, 06:17 |
CrankNicholsonDdtScheme.C chan
Maka Mohu
Rep Power: 18 |
CrankNicholsonDdtScheme.C changed between V 1.2 and 1.3 but I have no clue if the behavior changed. I'm still using V 1.2 and have been running a one-month simulation assuming it should be CrankNicholson 0.5 as the early post suggested. Do not ask me what is right and what is wrong. All I can say, enjoy :-)
/Maka |
May 24, 2006, 10:23 |
Could someone please explain t
Frank Bos
Rep Power: 18 |
Could someone please explain the differences (if any) between v1.2 and v1.3.
Conform the theory books, a value of 0.5 would makes more sense then 1.0. Frank
Frank Bos |
May 25, 2006, 05:22 |
No basic differences between 1
Mattijs Janssens
Rep Power: 26 |
No basic differences between 1.2 and 1.3.
//- Off-centering coefficient, 1 -> CN, less than one blends with EI |
May 26, 2006, 03:14 |
Many thanks Mattijs for your c
#11 |
Maka Mohu
Rep Power: 18 |
Many thanks Mattijs for your clear reply.
/Maka. |
May 29, 2006, 03:58 |
So for the record, Crank Nicho
#12 |
Frank Bos
Rep Power: 18 |
So for the record, Crank Nicholson 1.0 corresponds to fully second order accuracy, while a value less then 1.0 is less accurate.
Sorry to bother you again, but I am not really into the theory at this moment. Frank
Frank Bos |
October 20, 2013, 06:21 |
#13 |
Hi All,
When I choose CN, but set the factor to 1. The pressure is very prone to blow up, which lead to the simulation failure. Could anyone tell me what is the reason for this problem? Thank you very much. |
February 2, 2017, 10:45 |
#14 |
Rep Power: 12 |
please have a look at CrankNicolsonDdtScheme.H: Code:
The Crank-Nicosonl scheme is often unstable for complex flows in complex geometries and it is neccessary to "off-centre" the scheme to stabilize it ... Code:
The Crank-Nicolson coefficient for the implicit part of the RHS is related to the off-centering coefficient by cnCoeff = 1.0/(1.0 + ocCoeff); |
CrankNicholson returns wrong dimensions and sound speed when mesh is moving | lillberg | OpenFOAM Bugs | 6 | May 4, 2009 17:53 |
Bug caused by CrankNicholson scheme | cbeck | OpenFOAM Bugs | 8 | March 28, 2009 01:48 |
uds errors | major | FLUENT | 0 | May 28, 2008 10:49 |
Please help see this errors | liugx212 | OpenFOAM Running, Solving & CFD | 2 | December 9, 2005 12:34 |
Probelm with CrankNicholson scheme in channelOodles | maka | OpenFOAM Pre-Processing | 2 | November 2, 2005 10:09 |
