April 19, 2006, 10:05 |
Hi!
I'm trying to write a pre
Francesco Del Citto
Rep Power: 18 |
Hi!
I'm trying to write a preprocessor utility to set a tensor field on some sub-sets of cells in the mesh. I guess the best way to give input parameter is using a standard-shaped dictionary file, isn't it? The dictionary I'd like to read is something like this: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.0 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance "system"; local ""; class dictionary; object setGDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( box1 { box (-1 -2 -3) (1 2 3); x_axes (0 1 0); y_axes (1 0 0); G_diag (1e3 1e6 1e6); } box2 { box (-1 -2 -3) (1 2 3); x_axes (0 0 1); y_axes (1 0 0); G_diag (1e3 1e6 1e6); } ); // ************************************************** *********************** // So, I'd like to read the numer of boxes first ("2" in the example above) and then cycle on the entries. This should be more or less what OpenFOAM does while reading constant/polyMesh/boundary What are the right classes that implements this feature? Where can I find an example, just to see how it works? Thanks Francesco |
Dictionary | maka | OpenFOAM Bugs | 3 | February 18, 2009 10:26 |
RadialModel is undefined in dictionary | mahaputra | OpenFOAM Running, Solving & CFD | 1 | February 9, 2009 00:16 |
[swak4Foam] FunkySetFields dictionary | gschaider | OpenFOAM Community Contributions | 14 | December 3, 2008 21:13 |
[mesh manipulation] RotateMesh Dictionary File | titio | OpenFOAM Meshing & Mesh Conversion | 2 | March 12, 2008 10:15 |
Dictionary of fluid mechanics | Lam | Main CFD Forum | 1 | April 26, 2007 10:18 |
