Computation in parallel on AMD 64bit Red Hat Enterprise Linux AS release 3 Taroon Update 2
Old   October 21, 2005, 08:40
Default Hi there, I used the follo
zhengtong xie
ztxie is on a distinguished road
Hi there,
I used the following scripts (which was originally obtained from Eugene de Villiers but was modified a bit) running parrellel jobs on on AMD 64bit, Red Hat Enterprise Linux AS release 3 (Taroon Update 2)system with success. Someone might be interested.
qsub -l nodes=2:ppn=2 -l walltime=03:50:00 codef_script
## the "codef_script" is,
#!/bin/sh
# Set number of processors per node
# procs_per_node=2
cd $PBS_O_WORKDIR
ROOTDIR=/home/c/zxie/OpenFOAM/zxie-1.1/run/Cubes
CASENAME=stg444-8
CASEDIR=$ROOTDIR/$CASENAME
# make 4 proc node file
# cp $PBS_NODEFILE $CASEDIR/DP_NODEFILE
# cat $PBS_NODEFILE >> $CASEDIR/DP_NODEFILE
# DPS_NODEFILE=$CASEDIR/DP_NODEFILE
NUMPROCS=$(wc -l $PBS_NODEFILE | awk '{printf $1}')
## Create machinefile
MACHINE="hosts"
cat $PBS_NODEFILE | awk '{ printf "%s\n",$1 }' > $MACHINE
# `which decomposePar` $ROOTDIR $CASENAME
# start application
`which lamboot` -v $MACHINE
# `which mpirun` -np $NUMPROCS `which icoFoam` $ROOTDIR $CASENAME -parallel > $CASEDIR/log
`which mpirun` -np $NUMPROCS `which channelOodles` $ROOTDIR $CASENAME -parallel</dev/null> $CASEDIR/log
# `which lamhalt` -d
`which lamwipe` -v $MACHINE
Regards,
Zhengtong Xie
ztxie is offline   Reply With Quote
Precompiled 64bit linux installation milkovp OpenFOAM Installation 5 May 15, 2008 04:57
anyone use ICEM on linux 64bit system? littlelz Main CFD Forum 0 May 2, 2008 05:58
Fluent-AMD-64bit-Linux-Redhat MCB FLUENT 4 January 19, 2007 14:39
Linux for FLUENT6.2 (64bit) ROOZBEH FLUENT 3 November 12, 2006 06:49
ICEMCFD for 64bit Linux F.K. CFX 1 February 16, 2004 03:15
