October 18, 2005, 10:28 |
I'm new to OpenFOAM and
Frank Bos
Rep Power: 18 |
I'm new to OpenFOAM and looking for a flow solver which I can use in my PhD investigation. The most important features the solves must handle are: * 3D laminar flow at low Reynolds numbers * Prescribed wing motion * High amplitudes (several chord lengths) * High boundary velocities * 2nd order accuracy in space * 2nd order accuracy in time * Parallel solvable Could someone please comment on these features. When OpenFOAM is suitable for my needs (with acceptable (programming) efforts) I will probably make the switch from Fluent to OpenFOAM since Fluent is very pour with moving meshes. Thanks in advance, Regards, Frank
Frank Bos |
October 18, 2005, 10:56 |
The automatic mesh motion solv
Hrvoje Jasak
Rep Power: 33 |
The automatic mesh motion solver will be just the thing for you - all you need to do is to specify the motion of the surface mesha dn the motion of internal vertices is calculated for you.
The rest are all standard and well tested features of foam. Good luck, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 19, 2005, 07:53 |
Frank Bos
Rep Power: 18 |
Could someone please comment on the accuracy in space and time when moving meshes are used. The amplitudes are large.
Thanks, Frank
Frank Bos |
Moving mesh problem OpenFoam 141 | kassiotis | OpenFOAM Running, Solving & CFD | 30 | April 14, 2015 23:10 |
Software possibilities | Jacob A | Main CFD Forum | 0 | December 7, 2008 11:39 |
CFD of flapping wings | Yogesh babbar | FLUENT | 0 | July 15, 2006 11:04 |
PHD possibilities in canada | ramesh | Main CFD Forum | 6 | July 29, 2005 15:15 |
Delta Wings | R | Main CFD Forum | 1 | October 10, 2004 13:16 |
