IcoFoam
Old   May 2, 2005, 03:04
Default I want to solve the Navier-Sto
aap
Amalia Apalategui
aap is on a distinguished road
I want to solve the Navier-Stokes eq. for incompressible laminar regime and I have chosen the icoFoam solver. I am surprise that in the transportProperties file, only the viscosity is required, and the density??
Thanks
Amalia
aap is offline   Reply With Quote
Old   May 2, 2005, 03:10
Default That's correct. The viscosi
Hrvoje Jasak
hjasak will become famous soon enough
That's correct.
The viscosity is the kinematic viscosity (equals dynamic viscosity divided by the density); same for the pressure. This way, you only need the viscosity.
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   May 2, 2005, 05:20
Default I have run icoFoam and one get
aap
Amalia Apalategui
I have run icoFoam and one gets information about the Max. Courant number in the output. For the first time step is around 1, but for the next time steps becomes larger and larger. What does it mean? Does it mean that the cell size of the mesh and velocities do not match?
Thanks
Amalia
Old   May 2, 2005, 05:25
Default Have you tried with a smaller
henry is on a distinguished road
Have you tried with a smaller time step? Have you tried running with upwind? It sounds like either your case is not setup correctly or it is unstable with a Courant number as large as 1, you will have to play around to fix it.
henry is offline   Reply With Quote
Old   May 13, 2005, 10:36
Default hello, I want to couple the
chafi_fatima_zohra
hello,
I want to couple the equation of energy and the equations of Navie-Stokes in icoFoam and I want to add the appriximations of Boussinesq only in the direction of Z (push of archiméde).
my problem it is that icoFoam gives the solution of the following equation: UEqu=-grad p and me I want that only in the direction of Z, the component speed (w) must depend on grad p and gB(T-Tref). T: is has temperature
do you have an idea to add this term in the velocity equation on Z direction?
thank's
Old   May 13, 2005, 11:34
Default Hi chafi fatima zohra, I wo
gellert
I would recommend to take a look into rhoSimpleFoam, there is in principal
what you want, but restricted to steady state solutions. With help of or some terms
from buoyantFoam one should be able to construct the needed solver.
Old   May 13, 2005, 12:07
Default Hi chafi fatima zohra, me a
gellert
me again. Forget my former post. It was wrong, I'm sorry. rhoSimpleFoam is also
for compressible flows.
Marcus
Old   June 14, 2005, 08:22
Default hi chafi fatima zohra, i wa
chris10
i want to create a new solver for incompressible, laminar flow with boussinesq approximation. so i have combined "icoFoam" and "buoyantFoam". i have compiled my code successfully, but when i want to calculate an example i get the following error:
--> FOAM FATAL ERROR :
request for volScalarField rho from objectRegistry region0 failed
available objects of type volScalarField are
Did you have the same mistake? Which models do you use?
Old   August 10, 2005, 10:28
Default Hi, I was trying to modify
Kanyanta Valentine
valentine is on a distinguished road
I was trying to modify icoFoam solver to be able to also solve wall shear stresses for flow in pipes (laminar flow ofcourse) but am failing. would you please give me some ideas on building the code and compilation files and run it from FoamX. Please give me an example along side to look at.
Best regards.
valentine is offline   Reply With Quote
Old   August 10, 2005, 18:09
Default You might want to have a look
Mattijs Janssens
You might want to have a look at the postProcessing/stressComponents utility to find out about the coding.
Old   August 11, 2005, 06:29
Default Thanks for the information. I
  #11
Kanyanta Valentine
Thanks for the information. I will try to do that.
Old   August 15, 2005, 07:23
Default Hi, Still stack with solver
  #12
Kanyanta Valentine
Still stack with solver compilation. I was looking at one example on a built configuration file. what does the code
instance "/export/warhol/chris/.foam/apps/FoamX/User/applications/biscuitFoam ";
mean. I was tried to follow the same so I edited it to
"/export/home/valentine/.foam/apps/FoamX/User/applications/wallShearFoam ";
but its still not working. Please help.
Old   August 15, 2005, 13:52
Default Hi, forget about my earlier
  #13
Kanyanta Valentine
forget about my earlier message. I have managed around that problem.
best regards.
Old   May 27, 2012, 16:13
Default phi term in icoFoam
  #14
Aurelien
AGIR is on a distinguished road
I have a concern regarding the phi term in icoFoam.
I know its definition is: phi=rho*U, rho being the density.
In the icoFoam solver, a simplification is made, as there is no "rho" in the transient term, which makes sense since we consider an incompressible problem.
The problem is that if we make this simplification in a classic momentum equation from Navier Stokes system, there should not be any "rho" in the convective term, but simply "U" (velocity) instead of phi ( div(U, U) ).
My question is: what does OpenFOAM consider in this phi term ?
Here is the momentum equation solved in icoFoam:
fvVectorMatrix UEqn
fvm::ddt(U)                 // transient term
+ fvm::div(phi, U)          // convective term
- fvm::laplacian(nu, U)   // viscosity
solve(UEqn == -fvc::grad(p));
Thanks
AGIR is offline   Reply With Quote
Old   May 28, 2012, 02:30
Alberto Passalacqua
in incompressible solvers, where the momentum equation is divided by rho (constant), phi is defined as
surfaceScalarField phi
    IOobject
        "phi",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
        IOobject::AUTO_WRITE
    linearInterpolate(U) & mesh.Sf()
You can check this in ~/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/cfdTools/incompressible/createPhi.H
Best,
Alberto Passalacqua
Old   May 28, 2012, 08:30
Aurelien
Alright, thank you!
I checked the compressible cases, and that all makes sense now.
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
About phi in icoFoam kar OpenFOAM Running, Solving & CFD 3 February 20, 2008 05:20
Possible bug in icoFoam msrinath80 OpenFOAM Bugs 6 November 19, 2007 17:35
IcoFoam on AIX 53 ds2taieb OpenFOAM Installation 1 March 24, 2006 03:22
