Compile of the library is so slow
Old   July 15, 2005, 00:11
Default I found that PrimitivePatch di
liu
Xiaofeng Liu
liu is on a distinguished road
I found that PrimitivePatch didn't implement two functions: internalEdges() and boundaryEdges().
These two functions are used in PrimitivePatchInterpolation<patch>::faceToEdgeInte rpolate().
If we don't use "faceToEdgeInterpolate" function, everything is fine.
So I implemented those two functions in class PrimitivePatch.
But, when I try to compile the library with "wmake libso OpenFOAM" command, it's so so slow. The compiler works very hard to compile everything in the directory of OpenFOAM.
Since I only changed a little in the library code, is there any method to only compile these changes and make the library? I mean don't recompile all files to get those object files.
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   July 15, 2005, 02:49
Default PrimitivePatch is templated on
Hrvoje Jasak
PrimitivePatch is templated on the type of container that holds the faces and what the compiler is doing is OK - there is a LOT of code depending on PrimitivePatch. As for internal and boundary edges, the organisation of code has changed. Edges are ordered such that the internal edges come first, up to nInternalEdges() and are followed by the boundayr edges. I am not sure why the faceToEdgeInterpolate code was not fixed, but I'll have a look - should be easy.
Hrv
Hrvoje Jasak
slow simulation Shuo Main CFD Forum 2 February 28, 2008 19:07
V4 very slow! Steve Siemens 3 June 9, 2006 07:37
Converging very slow Q FLUENT 0 March 16, 2006 03:48
DPM slow evaporation Vix FLUENT 3 November 30, 2005 13:38
Slow convergence Jesper CFX 1 July 7, 2004 16:59
