Compressible flow with inlet velocity Ma%23601
Old   July 3, 2005, 13:01
Default Hello openFoam users, i jus
Klaus Wittig
klaus is on a distinguished road
i just started evaluating this promissing code and as usual in the beginning i have a problem. I just wanted to run the nacaAirfoil example in sonicTurbFoam with a free-stream velocity below sonic-speed (Ma<1) so that the velocity has to go supersonic only in a small area. But the solver is complaining that the free-stream Mach-Number must not be below 1:
--> FOAM FATAL ERROR : MachInf < 1.0, free stream must be supersonic
Is there a way to handle compressible flow for subsonic inlet conditions?
Best regards,
Klaus
klaus is offline   Reply With Quote
Old   July 3, 2005, 13:14
Default You have chosen a supersonicFr
henry is on a distinguished road
You have chosen a supersonicFreestream BC but specified a sub-sonic flow, why not choose a standard fixedValue inlet or inletOutlet condition?
henry is offline   Reply With Quote
Old   July 3, 2005, 15:43
Default Ups, you got me. I was hast
Klaus Wittig
Ups,
you got me. I was hasty and i missed to change this entry in the inlet condition of U.
INLE1
type supersonicFreeStream;
pInf 100000;
TInf 300;
UInf (60.0 14.816 0);
To:
type fixedValue;
value uniform (60.0 14.816 0);
I also changed p now.
OUTL2
{type pressureTransmissive;
pInf 100000;
lInf 1;
To:
OUTL2
type fixedValue;
value uniform 100000;
I will try it soon.
Thanks for the quick reply and for all your effort with the software,
Klaus
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Internal Flow BCs for Compressible inlet flow Katie FLUENT 2 March 3, 2012 17:35
Mass flow inlet compressible flow richard FLUENT 2 June 1, 2008 11:44
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
velocity or mass flow inlet? Silvia FLUENT 1 August 12, 2005 13:55
