Karman vortex street
Old   June 8, 2005, 09:11
Default Hi all, I want to simulate
gellert
Hi all,
I want to simulate the flow around a cylinder and the Karman vortex street appearing
behind. Would icoFoam be the right solver? Or is it better/easier to use an LES solver
like oodles?
(Geometry should be a channel with inlet/outlet, rigid walls on top and bottom and
empty b.c. left and right.)
Thank you.
Marcus
Old   June 8, 2005, 09:23
Default This is a difficult problem be
Eugene de Villiers
eugene is on a distinguished road
This is a difficult problem because you have laminar and turbulent flow. Your best (and probably only) bet would be LES with a dynamic SGS model to cope with transition. I have never used Foam's dynamic models though, so I cant help you with this aspect.
eugene is offline   Reply With Quote
Old   June 8, 2005, 09:27
Default What Reynolds number do you wa
henry is on a distinguished road
What Reynolds number do you want to run at?
henry is offline   Reply With Quote
Old   June 8, 2005, 10:25
Default I choose the inflow as parabol
gellert
I choose the inflow as parabolic profile. The Reynolds number will be around Re=200.
Meanwhile I already tested icoFoam and get a steady state without detaching
vortices nearly independent on the used resolution.
On the other hand the needed resolution is not that high, so a direct simulation should
be possible!?
Old   June 8, 2005, 10:36
Default At Re=200 you do not need LES
At Re=200 you do not need LES and running in 2D is probably OK but you might want to check if you are likely to get 3D structures at this Re.
If your mesh and initial conditions are symmetric you may get a symmetric stready solution unless you perturb it to break the symmetry. Also you should use use second-order differencing in time and space. What schemes have you chosen?
Old   June 8, 2005, 11:56
Default The center of the cylinder is
gellert
The center of the cylinder is not exactly placed on the symmetry axis of the channel and inflow.
The chosen schemes are CrankNicholson for time derivatives and (Gauss) upwind for spatial
derivatives. As already mentioned the solution looks symmetric and steady.
Old   June 8, 2005, 12:01
Default I am not surprised you get a s
I am not surprised you get a symmetric and steady solution using upwind spatial differencing, why did you choose such a low-order scheme? Why not use linear (central-differencing)?
Old   June 8, 2005, 16:48
Default Ok, I changed to (Gauss) linea
gellert
Ok, I changed to (Gauss) linear scheme as found in the cavity test case. Nevertheless only a steady-state is reached.
I prepared a short web page with some pictures, the case files and some calculation data. If somebody wants to take
a look and suggest some further improvements, I would be happy.
The URL is http://www-user.tu-cottbus.de/~gelle...an/karman.html
-marcus
Old   June 8, 2005, 17:01
Default What happened when you perturb
What happened when you perturbed the solution to break symmetry?
Old   June 8, 2005, 17:16
Default You need to trigger the instab
Hrvoje Jasak
You need to trigger the instability and then all will be well.
Try this: use the current solution and make the top and bottom of the channel to be fixedVelocity boundaries (not sure what you're using now), but specify different velocities at top and bottom. Then, run the simulation for a hundred time-steps or so - this will create a non-symmetric solution. Using that, restart with the proper boundary conditions and the cylinder will start shedding.
If this sounds too complex to you :-) and you're brave, try relaxing the pressure tolerance, run a few time-steps (checking the solution visually). The run will be slowly blowing up. When you get some assymetry (but before the whole thing has blown to bits!), tighten the tolerances again and you'll get the shedding.
This is a fun problem - enjoy!
Hrv
Hrvoje Jasak
Old   June 8, 2005, 17:43
Default Increase the Reynolds number (
  #11
Eugene de Villiers
Increase the Reynolds number (by lowering nu) until the case starts to shed, then change it back to normal.
Old   June 8, 2005, 19:26
Default Your mesh is not 2D, it's 2 ce
  #12
Your mesh is not 2D, it's 2 cells thick with empty patches on the front and back which allows nearly all the flow to "leak out" through those boundaries rendering the simulation totally incorrect. Apart from this gross error in the mesh it is also highly distorted and could be greatly improved in structure. It is also rather coarse in the wake-region.
I don't think the use of forth-order differencing is a good idea for this case and linear should be fine particularly on such a non-orthogonal mesh. Try running check mesh on it and you will see what I mean.
Old   June 9, 2005, 05:45
Default Thank you for all your help. I
  #13
gellert
Thank you for all your help. I will first reduce the 3rd direction to one cell thickness and
try to perturb the initial conditions. If it's not 'enough' next step will be improving
the mesh (for me that is most time consuming).
Old   June 9, 2005, 05:53
Default Given that your geometry is qu
  #14
Given that your geometry is quite assymetric you probably won't need to perturb the initial conditions. However, I would strongly recommend you improve and refine the mesh particularly in the wake region. Take a look at the mesh structure used in the plateHole stressedFoam tutorial for guidance.
Old   June 17, 2005, 12:18
Default After some optimisations now t
  #15
gellert
After some optimisations now the vortex shedding appears (albeit at slightly higher Re as expected).
I updated the above mentioned web page. The complete case file is also there - perhaps usable as
additinal icoFoam tutorial case?
-marcus
Old   June 17, 2005, 12:19
  #16
gellert
additional icoFoam tutorial case?
-marcus
low Re (30-170) Karman vortex street Sponi FLUENT 0 March 16, 2007 13:27
Von karman Vortex street yoshi Main CFD Forum 6 September 10, 2005 22:09
karman vortex street michael Siemens 5 April 30, 2003 05:04
Karman vortex street Zhipeng FLUENT 5 June 24, 2002 11:00
Karman vortex street Achilleas Tsompanos Main CFD Forum 4 April 25, 2000 07:26
