Laminar flow with CHEMKIN mechanism
Old   May 24, 2005, 07:16
Default Dear people, I modified the d
bram de jager
bram_de_jager is on a distinguished road
Dear people,
I modified the dieselFoam application (removed spray part and Chalmers PaSR model) in order to simulate laminar detailed chemistry with OpenFoam. However, looking at the transport equation definition for the species vector, there is no laminar diffusion term defined. Has anyone implemented this into FOAM? What I would like to do is, to implement some mixture-averaged diffusion coefficient (all species diffuse into N2)?
Is this available somewhere within Foam or the community allready? Or is this something that I have to implement myself?
Thanks in advance,
Bram
bram_de_jager is offline   Reply With Quote
Old   May 24, 2005, 07:40
Default Hi, that is correct, the Sc
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
that is correct, the Schmidt number is set to 1 here, i.e mass diffusion = momentum diffusion,
and all species have the same diffusion coeff,
this is not a worse assumption than others for the dieselFoam application.
If you want to have something else you have to write it yourself, but that should be quite easy.
The diffucult part was the chemkin reader
N
niklas is offline   Reply With Quote
Chemkin mechanism import of surface chemistry Claud FLUENT 2 August 5, 2013 08:03
laminar flow mechanism kk FLUENT 4 February 16, 2007 16:35
Laminar Finite-Rate in combination with Chemkin Jo FLUENT 0 February 12, 2007 05:38
Laminar flow mech FLUENT 4 February 1, 2007 14:18
CFD-ACE laminar flow Mahesh Main CFD Forum 12 January 13, 2005 09:14
