May 11, 2005, 14:27 |
Dear all,
since I'm doing s
Dear all,
since I'm doing some testing of a modified turbulence model based upon the LRR implementation, I'd like to solve an additional equation for a tensor field giving me an idea about its quality - this field should be a copy of R_. I browsed all the messages posted here, but, unfortunately, cannot find a solution of my problem. First of all, I defined a new 'volTensorField' in my .H-File I named 'HELP1', tmp<voltensorfield> HELP1() const { return HELP1_; } which is set to a fixed set of values in .C afterwards: HELP1_ ( IOobject ( "HELP1", runTime_.timeName(), runTime_, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh_, dimensionedTensor ( "zero", R_.dimensions(), tensor ( 1,0,0, 0,2,0, 0,0,3 ) ) ). To solve this, I copy the field values of R_ onto HELP1_ and define the additional equation as follwing: HELP1_ = R_; tmp<fvtensormatrix> HELP1Eqn ( fvm::ddt(HELP1_) == P ); solve(HELP1Eqn); where 'P' has the correct dimensions. All the fvSchemes and other input-files are set, compilation is done without any messages and the code runs properly (I'm using turbFoam). When I add another term on the left- or right-hand-side of 'HELP1Eqn' - i.e. + fvm::div(phi_, HELP1_) - I get the message from Foam --> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a calculatedFvPatchField. You are probably trying to solve for a field with a calculated or default boundary conditions. My question now: what's wrong here? Where is something missing? Do I have to modify an argument list? This might be a stupid question - my last C++-course at uni is years ago - but I wouldn't mind some useful hints... Thanks in advance, Rene |
May 11, 2005, 14:34 |
The problem is that you have n
Rep Power: 22 |
The problem is that you have not set any boundary conditions for HELP1_ and have let them default to calculatedFvPatchField which of course you cannot use in a transport equation. You could either read HELP1_ and set the BCs in the file or obtain the BC types from R_.
May 12, 2005, 04:36 |
Thanks Henry!
After setting
Thanks Henry!
After setting 'MUST_READ' to HELP1_ all works fine. |
Display Modes | |
Transport equation for an Additional Variable | HariBol | CFX | 2 | November 26, 2007 17:07 |
Additional Variable - Diffusive Transport Equation | RadheShyam Das | CFX | 3 | October 18, 2007 13:35 |
Solving Additional Variable in CFX? | Tuks | CFX | 6 | November 18, 2005 12:40 |
Implementing additional equation? | Pratap | FLUENT | 1 | December 4, 2004 21:32 |
additional equation for heat transport | Sascha Becker | CFX | 2 | December 20, 1999 03:58 |
