April 9, 2013, 10:34 |
BC for outlet - interFoam
Pedro Ramos
Rep Power: 14 |
Hello!
I'm doing the flow simulation around a cylinder but this happens: http://www.cfd-online.com/Forums/att...m-picture1.jpg I'm thinking that the problem ins the boundary condition on "outlet". What you suggest? Best regards. |
April 9, 2013, 10:40 |
Robert
Rep Power: 13 |
1. What do we see on this picture? I guess it's alpha?
2. Where's the cylinder located? 3. Could you please post your BC files? Thanks, Robert |
April 9, 2013, 10:49 |
Pedro Ramos
Rep Power: 14 |
Hi Robert!
See this video and you will understand: https://dl.dropbox.com/u/22662045/8abril2.avi Please, take a look on my files: https://dl.dropbox.com/u/22662045/pier8abril2.rar |
April 9, 2013, 11:46 |
Robert
Rep Power: 13 |
my first guess is that you should change your pressure BC. I'ts right to fix p_rgh to zero, but doing the same with p, which is p_rgh + rho*H*g won't work. I would give "phaseHydrostaticPressure" a try. Best, Robert |
April 9, 2013, 12:01 |
Pedro Ramos
Rep Power: 14 |
Thanks. I'm sorry but I'm new in openfoam, so i didn't understand clearly what you suggest.
"phaseHydrostaticPressure" is a BC? should I change p for all patches or only in outlet? |
April 9, 2013, 12:18 |
Robert
Rep Power: 13 |
Oh, right. Sorry!
phaseHydrostaticPressure is a BC for pressure. Try this for p --> outlet type phaseHydrostaticPressure; phaseName alpha1; rho none; pRefValue 0; pRefPoint (0 0 0); // fill in z-coordinate of the water surface for z value uniform 0; I hope this helps. Please report. |
April 9, 2013, 13:14 |
Pedro Ramos
Rep Power: 14 |
thank you so much for your help. unfortunately, it dind't work. see for yourself: https://dl.dropbox.com/u/22662045/pier9april2.avi
the video is short but it seems that the problem is already there. please, can you help me? i am with this problem for weeks.... thanks |
April 9, 2013, 15:43 |
Robert
Rep Power: 13 |
Hey,
I've had a closer look at your video and now I've realized that the graph in the lower right corner shows the plot of the values along the flow direction. You see that the pressure is high at the inlet and drops to zero at the outlet, because you fixed it to zero. Have you tried to set the BC for U at the outlet to "zeroGradient"? I'll try some things tomorrow on my workstation, there's no OpenFOAM available here right now. But zeroGradient might already fix this. Best regards, Robert |
April 10, 2013, 07:03 |
#9 |
Pedro Ramos
Rep Power: 14 |
It didn't work again :/ Video is here: https://dl.dropbox.com/u/22662045/pier9abril3.avi
And if the problem isn't in the outlet BC? The files are here: https://dl.dropbox.com/u/22662045/pier9abril3.rar I appreciate a little help! |
April 16, 2013, 11:25 |
#10 |
Pedro Ramos
Rep Power: 14 |
Hello again... it didn'w work... i'm working in this for weeks...it will turning me crazy!
Display Modes | |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 07:36 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 16:26 |
Perfect fluid implementation - interFoam | Gaetano | OpenFOAM Programming & Development | 7 | January 26, 2013 13:54 |
Segmentation fault in interFoam run through openMPI | voingiappone | OpenFOAM | 16 | November 2, 2011 07:49 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 22:58 |
