March 16, 2005, 12:14 |
Try DB() -> db()
Chris Greenshields
Try DB() -> db()
March 16, 2005, 12:16 |
To clarify, I mean:
replace D
Chris Greenshields
To clarify, I mean:
replace DB() with db() |
March 16, 2005, 12:19 |
Also you might find it useful
Rep Power: 22 |
Also you might find it useful to read the ReleaseNotes that are provided with 1.1
March 17, 2005, 05:00 |
replacing DB with db is not wo
Daniele Panara
replacing DB with db is not working, fortunately I got the right corrections from Hrvoje.
Thanks again... I have another question, I have another application that is not working on 1.1 I get the following error message: GradU.C: In function `int main(int, char**)': GradU.C:104: error: 'struct Foam::volTensorField' has no member named 'xy' make: *** [Make/linuxOpt/GradU.o] Error 1 it refers to the line: volTensorField GradU ... GradU.xy() Can somebody help me? Daniele |
March 17, 2005, 05:02 |
Try:
gradU.component(tensor
Hrvoje Jasak
Rep Power: 33 |
Try:
gradU.component(tensor::XY) Hrv
March 17, 2005, 05:07 |
Did you application work in 1.
Rep Power: 22 |
Did you application work in 1.0.2? volTensorField has never had a member function xy() so it should fail to compile in all versions of FOAM.
March 17, 2005, 05:16 |
the modification
gradU.comp
Daniele Panara
the modification
gradU.component(tensor::XY) is working, thanks again!! Yes, my application was working well in 1.0.2, I am sure. Daniele |
March 17, 2005, 05:19 |
It doesn't make any sense to m
Rep Power: 22 |
It doesn't make any sense to me that the .xy() function call for volTensorField would work in 1.1 but not in 1.0.2 given that the function isn't in eitehr version of the code. Do you still have a working installation of 1.0.2? Could you try compiling that piece of code and send me the details?
March 17, 2005, 05:31 |
I apologize,
I tryed to reco
Daniele Panara
I apologize,
I tryed to recompile my application in 1.0.2 and it is not working.. Since I used that application to get results before, the only explanation for my mistache could be that I changed the source file in that way without recompiling it. I am very sorry. |
Coordinate conversion | Sae woong Kil | CFX | 2 | November 28, 2008 10:32 |
conversion | hari | Main CFD Forum | 0 | December 5, 2007 23:26 |
Conversion 13 14 of dynamicBodyFvMesh | lr103476 | OpenFOAM Running, Solving & CFD | 2 | June 19, 2007 05:38 |
conversion to iges | buildmesher | CFX | 0 | May 6, 2003 17:51 |
tet to hex conversion? | Henry | Main CFD Forum | 10 | June 8, 2001 07:03 |
