March 8, 2005, 12:52 |
Hi all,
I am trying to use a
diablo80@web.de
Rep Power: 17 |
Hi all,
I am trying to use a dynamic model for LES, but since the first iteration I got "nan" in all solvers... Has anyone succeeded in using dyn models? Do I need to do anything else, other than switch the name of the model in turbulenceProperties? (I started with the "static" model, in my case 1Eq, and than after several timesteps, switched to dyn model) Thanks, Luiz |
March 8, 2005, 12:56 |
Do you have a zero turbulence
Hrvoje Jasak
Rep Power: 33 |
Do you have a zero turbulence initial condition? That would do it - have a look at the files in zero directory and make sure they make sense.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 8, 2005, 12:59 |
Which dynamic model are you tr
Rep Power: 22 |
Which dynamic model are you trying? I have just tried dynSmagorinsky on the tutorial case and it ran fine.
There may be an issue with the dynamic models starting from a zero or even uniform U field. Try running with a non-dynamic model first and then restart with a dynamic model. |
March 8, 2005, 13:03 |
I dont think you can yet switc
Eugene de Villiers
Rep Power: 21 |
I dont think you can yet switch turbulence models in mid-calculation.
March 8, 2005, 13:04 |
You can restart with a differe
Rep Power: 22 |
You can restart with a different turbulence model, I do it frequently.
March 8, 2005, 13:07 |
Hi Henry,
It ran fine with dy
diablo80@web.de
Rep Power: 17 |
Hi Henry,
It ran fine with dynSmagorinski, but it blows with dynOneEq... I did run first with a static (non-dyn) model. Thanks a lot |
March 8, 2005, 13:10 |
OK, I see what is going on. T
Rep Power: 22 |
OK, I see what is going on. The problem is the dynamic models do ynot currently have stabilisation in the terms average(LL && MM)/average(MM && MM) where MM may be locally (or even globally) zero. I will look at the dynOneEq... and tell you what you need to change.
March 8, 2005, 13:51 |
Try this
http://www.cfd-on
Rep Power: 22 |
March 8, 2005, 15:41 |
Hi Henry,
I tried but it did
#9 |
diablo80@web.de
Rep Power: 17 |
Hi Henry,
I tried but it did not worked. Did it work for you? Thanks. Luiz |
March 8, 2005, 15:44 |
Hi Henry,
I tried but it did
#10 |
diablo80@web.de
Rep Power: 17 |
Hi Henry,
I tried but it did not work. Did it work for you? Thanks. Luiz |
Yes, it worked fine for me. P
#11 |
Rep Power: 22 |
Yes, it worked fine for me. Put some print statements in it to check you are calling the new functions, the ones with the limiters in are at the top of the file.
Two-fluid models vs mixture models for bubbly flows | Hansong Tang | Main CFD Forum | 6 | December 8, 2009 03:21 |
Failed dimensional check with dynamic LES models | alberto | OpenFOAM Bugs | 9 | September 5, 2007 22:57 |
LES dynamic models fail dimensional check | alberto | OpenFOAM Running, Solving & CFD | 0 | June 11, 2007 13:23 |
Dynamic Mesh Models | Marc | Main CFD Forum | 1 | November 29, 2003 12:21 |
Dynamic Subgrid Models | Bono | Main CFD Forum | 2 | November 27, 2001 16:50 |
