CHT with radiation, inner fluid region shows unphysical behavior |
December 9, 2022, 06:20 |
Eren
Rep Power: 8 |
Hello again dear CFD nerds!
I have a CHT case with radiation (external beam, or solar load) it is basically: Outer region (fluid), middle region (solid), and inner region (fluid). I want to calculate the irradiation inside the inner region. Top picture shows the outer region, and bottom picture shows the inner region. I think there is a problem with my middle region BCs. Because outer region and inner region G fields are not really in agreement. (outside region field shows an expected behavior, walls are reflective and top is transparent). Middle region is transparent, but I realised solver does not even reads the boundaryradiation file in middle(solid) region! So what should be the appropriate BC to correctly calculate irradiation inside the inner region? Any help willbe appreciated! |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 02:23 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
fluid fluid radiation properties | IronLyon | CFX | 5 | March 18, 2019 16:40 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
