error message
Old   March 25, 2009, 04:05
Default error message
vivien
vivien is on a distinguished road
Hi, everyone,
I am running a transient case with icoFoam, everything looks Ok, but I got following error messages, it looks to me that simulation is not diverged? Besides, when I change in the controlDict to use the latest time which has been stored(2.23s) as the new startTime, simulation carrys on without giving any error messages(ie. no error at time instance 2.2343689). Can somebody give suggestions?
Thanks!!
Vivien
Time = 2.2343543
Courant Number mean: 0.0053828188 max: 0.64918121
deltaT = 7.2753478e-06
DILUPBiCG: Solving for Ux, Initial residual = 5.3138552e-06, Final residual = 3.1175137e-09, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 4.7171651e-06, Final residual = 9.1354938e-10, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 7.9805167e-06, Final residual = 4.9745108e-10, No Iterations 5
GAMG: Solving for p, Initial residual = 0.00019002876, Final residual = 3.44714e-06, No Iterations 5
GAMG: Solving for p, Initial residual = 0.00067228588, Final residual = 6.0058329e-06, No Iterations 2
time step continuity errors : sum local = 1.516467e-10, global = 4.4451297e-12, cumulative = 7.695148e-11
DILUPBiCG: Solving for T, Initial residual = 1.041974e-05, Final residual = 4.729978e-09, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 2.6833676e-07, Final residual = 2.6833676e-07, No Iterations 0
ExecutionTime = 11673.61 s ClockTime = 11714 s
Time = 2.2343616
Courant Number mean: 0.0053827606 max: 0.64916911
DILUPBiCG: Solving for Ux, Initial residual = 4.773095e-06, Final residual = 2.7885961e-09, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 4.4754794e-06, Final residual = 6.4518825e-09, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 7.4329129e-06, Final residual = 3.0449529e-09, No Iterations 2
GAMG: Solving for p, Initial residual = 0.00018720649, Final residual = 3.4225106e-06, No Iterations 5
GAMG: Solving for p, Initial residual = 0.00067818591, Final residual = 6.0578516e-06, No Iterations 2
time step continuity errors : sum local = 1.5187123e-10, global = -4.4411745e-12, cumulative = 7.2510306e-11
DILUPBiCG: Solving for T, Initial residual = 1.0421422e-05, Final residual = 9.3188894e-09, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 2.7852124e-07, Final residual = 2.7852124e-07, No Iterations 0
ExecutionTime = 11674.1 s ClockTime = 11715 s
Time = 2.2343689
Courant Number mean: 0.0053826524 max: 0.64916023
DILUPBiCG: Solving for Ux, Initial residual = 5.3133965e-06, Final residual = 3.1193758e-09, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 4.71639e-06, Final residual = 9.1425432e-10, No Iterations 3
[12] #0 Foam::error:rintStack(Foam::Ostream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[12] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[12] #2 __restore_rt at sigaction.c:0
[12] #3 void Foam:rocessorLduInterface::compressedSend<double >(Foam::Pstream::commsTypes, Foam::UList<double> const&) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[12] #4 Foam:rocessorFvPatchField<Foam::Vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, Foam::Pstream::commsTypes) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[14] #0 Foam::error:rintStack(Foam::Ostream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[14] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[14] #2 __restore_rt at sigaction.c:0
[14] #3 void Foam:rocessorLduInterface::compressedSend<double >(Foam::Pstream::commsTypes, Foam::UList<double> const&) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[14] #4 Foam:rocessorFvPatchField<Foam::Vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, Foam::Pstream::commsTypes) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[14] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[14] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<Foam::Field<double> > const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[14] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[14] #8 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::Istream&) in "/home/durant/OpenFOAM/dep16039-1.5/applications/bin/linux64GccDPOpt/caFoam"
[14] #9 main in "/home/durant/OpenFOAM/dep16039-1.5/applications/bin/linux64GccDPOpt/caFoam"
[14] #10 __libc_start_main in "/lib64/libc.so.6"
[14] #11 Foam::regIOobject::readIfModified() in "/home/durant/OpenFOAM/dep16039-1.5/applications/bin/linux64GccDPOpt/caFoam"
[13] #0 Foam::error:rintStack(Foam::Ostream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[13] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[13] #2 __restore_rt at sigaction.c:0
[13] #3 void Foam:rocessorLduInterface::compressedSend<double >(Foam::Pstream::commsTypes, Foam::UList<double> const&) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[13] #4 Foam:rocessorFvPatchField<Foam::Vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, Foam::Pstream::commsTypes) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
[13] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[13] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<Foam::Field<double> > const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[13] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[13] #8 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::Istream&) in "/home/durant/OpenFOAM/dep16039-1.5/applications/bin/linux64GccDPOpt/caFoam"
[13] #9 main in "/home/durant/OpenFOAM/dep16039-1.5/applications/bin/linux64GccDPOpt/caFoam"
[13] #10 __libc_start_main in "/lib64/libc.so.6"
[13] #11 Foam::regIOobject::readIfModified()GAMMA: signal 15: process instance 13 aborting on node ls0185...
[12] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[12] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<Foam::Field<double> > const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char) const in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
[12] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "
vivien is offline   Reply With Quote
Old   March 26, 2009, 03:38
vivien
Can somebody help me?
Thanks in advance!
Vivien
Old   March 26, 2009, 05:04
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Seems like a similar error to one I had before. Try:
http://www.cfd-online.com/Forums/ope...-parallel.html
Those are very large times and very small time steps!
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   March 26, 2009, 05:08
Juho Peltola
juho is on a distinguished road
Hi Vivien,
To me it looks like a floating point exception ie. a division by zero or something like that.
"12] #1 Foam::sigFpe::sigFpeHandler(int) in"
Fpe = Floating point exception
To replicate the problem on restart it is important that you save the results in binary format. You can set the write format in the system/controlDict file by setting it ascii or binary. I't ascii by default I believe.
--Juho
juho is offline   Reply With Quote
