Help with new viscosity modell
Old   March 31, 2009, 08:54
Default Help with new viscosity modell
Nabil
Mikro is on a distinguished road
Hello everyone,
I'm trying to implement a new viscosity modell for blood (well several acctually) and i'm having a problem with this one: (Powell-Eyring modell)
nuInf_+(nu0_-nuInf_)*scalar(1)/(sinh(lambda_*strainRate())*lambda_*strainRate());
The linking of the library goes without any problem, it's when i run nonNewtonianIcoFoam that the solver crashes, I was hoping that someone with better knowledge in OpenFoam might tell me were the problem is...
This is errors i get when i try to run it, incase it helps anyone to se it better...
#0 Foam::error:rintStack(Foam::Ostream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xb7fd7420]
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&)
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)
#6 Foam::viscosityModels::PowellEyring::calcNu() const
#7 Foam::viscosityModels::PowellEyring::PowellEyring( Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::surfaceMesh> const&)
#8 Foam::viscosityModel::adddictionaryConstructorToTa ble<Foam::viscosityModels::PowellEyring>::New(Foam ::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::surfaceMesh> const&)
#9 Foam::viscosityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::surfaceMesh> const&)
#10 Foam::singlePhaseTransportModel::singlePhaseTransp ortModel(Foam::GeometricField<Foam::Vector<double> , Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::surfaceMesh> const&)
#11 main
#12 __libc_start_main
#13 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122
Also i might poit out that this is the sixth modell i'v done, and the other five work perfectly fine with nonNewtonianIcoFoam...
Mikro is offline   Reply With Quote
Old   March 31, 2009, 10:27
Juho Peltola
juho is on a distinguished road
It's a divide by zero.
Fpe = floating point exception
"divide"
I'm not 100% about the syntax, but you should use something like:
dimensionedScalar small('small', dimensionSet(<correct dimensions>),1e-10);
.../max(small, ...)
juho is offline   Reply With Quote
Old   April 1, 2009, 08:21
Nabil
thanks for the help, i tried the way u'v suggested, but it's still not correct...
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 20:34
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 08:00
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
