twoPhaseEulerFoam - floating point exception (nutb)
Old   April 9, 2009, 05:07
Default twoPhaseEulerFoam - floating point exception (nutb)
Hectux is on a distinguished road
I just started with the twoPhaseEulerFoam Solver.
I got while "calculating nutb" a floating point exception.
I saw that nutb is turbulent kinematic viscosity of phase b. Where could be the problem?
Br
Hectux is offline   Reply With Quote
Old   April 9, 2009, 10:41
Juho Peltola
juho is on a distinguished road
Originally Posted by Hectux View Post
Br
I guess you're using 1.5? If you look at the createFields.H in the solvers's folder and search for the line "Calculating field nutb" you will find:
Info<< "Calculating field nutb\n" << endl;
volScalarField nutb
IOobject
"nutb",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
Cmu*sqr(k)/epsilon
Most floating point exceptions are divide-by-zeros. As you can see the square of the turbulent kinetic energy, k, is divided by epsilon. I guess you have a zero in your epsilon field? You can eliminate the floating point exception by using a small value such as 1e-13 instead.
However, in 1.5.x version this problem is eliminated by using:
Cmu*sqr(k)/max(epsilon, dimensionedScalar("smallEps",epsilon.dimensions(), 1e-6))
Where the value of epsilon in the denominator is limited to larger than 1e-6 and thus removing the possibility of a floating point exception caused by a zero in the epsilon field.
So another option is to update to 1.5.x or to modify the line yourself and recompile the solver.
juho is offline   Reply With Quote
Floating point exception? Ricky Wong FLUENT 19 March 28, 2020 15:32
Error : floating point exception; overflow. maryam CFX 3 May 18, 2010 07:44
Floating Point Exception?? Alex FLUENT 2 April 21, 2009 01:29
CFX error, Floating point exception Riyaz Main CFD Forum 0 November 14, 2008 06:30
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
