April 29, 2009, 17:18 |
Error: icoLagrangianFoam
xinguang cui
Dear all:
When I don't compute the case from 0, there is some error information as follows. Would you like to give me some advice about it? Thanks and best regards! Create time Create mesh for time = 0.5 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Constructing Particles unexpected class name IncompressibleCloud expected regIOobject while reading object positions file: /home/cui/OpenFOAM/cui-1.5/applications/solver/save_2/IcoLagrangianFoam/cavityLagrange/0.5/lagrangian/defaultCloud/positions at line 15. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 114. FOAM exiting cui@mfc-falter:~/OpenFOAM/cui-1.5/applications/solver/save_2/IcoLagrangianFoam/cavityLagrange> |
April 30, 2009, 14:41 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Seems like the Restart is broken. I'll have a look, but don't hold your breath. If you happen to find a fix before me let me know.
Bernhard |
May 4, 2009, 02:20 |
xinguang cui
Thanks! I will try my best to fix it, but I am good at C++ and OpenFOAM, it is possible to take long time for me to do.
May 4, 2009, 04:03 |
Hi xinguang
What's you position file like? OpenFOAM read and write lagrangian field through the class of IOField. In "positions" file the word "IncompressibleCloud" should not be included. Junwei |
May 4, 2009, 06:56 |
hi gschaider
Hi gschaider and xinguang
The restating problem of icoLagrangianFoam is fixed. The revised version is attached Regards,Junwei |
May 4, 2009, 07:29 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
May 4, 2009, 08:43 |
gschaider
yes,gschaider. I have one. User name: sujunwei
Junwei |
May 4, 2009, 16:54 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
May 28, 2009, 07:27 |
i tried to run icoLagrangianFoam and I am using OF-1.5-dev. With the command icoLagrangianFoam i got following message and do not know how to go on. keyword useMomentumSource is undefined in dictionary "/home/michel/OpenFOAM/michel-1.5-dev/diplom/icoLagrangianFoam/channelParticles/constant/cloudProperties" file: /home/michel/OpenFOAM/michel-1.5-dev/diplom/icoLagrangianFoam/channelParticles/constant/cloudProperties from line 27 to line 27. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 213. Can somebody help me, please. I try to understand the icoLagrangian case to make a turbLagrangianFoam solver with dynamicMesh and VOF Method. Best regards Michél |
May 28, 2009, 11:05 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
useMomentumSource 0; should be sufficient Bernhard |
May 28, 2009, 11:24 |
#11 |
xinguang cui
Yes! The answer is very correct. But as you are a beginner, I l would like to add some words. From the error information, you could find useMomentSource should be defined in the file of clouldProperties. So you need to add the lines as foamer in the file of clouldProperties. |
May 29, 2009, 03:33 |
#12 |
Thank you Bernhard and Xinguang - i will try it
June 11, 2009, 04:45 |
create Particle
#13 |
Hello again,
can me somebody explain useMomentumSource and subCycles, please. The solver is working but I have new problems in using this solver because I want to inject more than 1 particle per timeStep. I thought this I can set the number of particle injection in the injectorProperties file but this is not the right way. Thanks for your help best regards Michel |
June 11, 2009, 04:50 |
#14 |
xinguang cui
the useMomentumSource is the source term from the particles. It is Momentum Source. If you want to know more about it you need to see the file of HardBallParticle.C or IncompressibleCloud.C
For the code, it only could inject one particle per time step. If you want to inject more than one, you need to do some other work. |
June 11, 2009, 09:33 |
#15 |
xinguang cui
I am sorry that I know few about your project. And I am so familiar with the icoLagrangianFoam.
But I think if you only wants to add particle in same step: One way is to change something in the code, another way is to set up the time step with very small time step, it seems that the particles are added in one step. |
June 11, 2009, 11:18 |
#16 |
thank you for your advice.
regards Michel |
November 11, 2009, 12:26 |
#17 |
xinguang cui
Another bug for icoLagrangianFoam in parallelized computing
I hope all of you are fine. There is a big bug on "icoLagrangianFoam" in the case of paralleling computing. There is no problem for the case are computed using one process. If the mesh is decomposed in the z direction for cavity, the particle could be moved, but the result is different with case of using one process, it is the same situation for the y direction. The worst thing is that the particles can not be moved if it is decomposed in x direction after the computation starts some steps. From the position file, it could be seen that some particles dwells on the location of 0.05 in the folder of "processor0", and on another folder of "processor1" is also the same situation. It is absolutely there is some problem during the process for one particle transferring to another processor. Does anyone also find the bug? It is very sad I know few about the part of transfer field of particles. Who would like to give me some advice on it? Thanks and best wishes! |
