February 19, 2024, 09:49 |
waveFoam: command not found
Marion Sant
Rep Power: 2 |
Hi all.
I finally succesfully compiled waves 2 foam with Ubuntu 20.04 and Openfoam2206. The compilation show this error which makes me unable to run waveFoam: g++ -std=c++14 -m64 -pthread -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/usr/lib/openfoam/openfoam2206/applications/solvers/multiphase/VoF -I/usr/lib/openfoam/openfoam2206/src/phaseSystemModels/twoPhaseInter/incompressibleInterPhaseTransportModel/lnInclude -I/usr/lib/openfoam/openfoam2206/src/phaseSystemModels/twoPhaseInter/VoFphaseIncompressibleTurbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude -I/usr/lib/openfoam/openfoam2206/src/meshTools/lnInclude -I/usr/lib/openfoam/openfoam2206/src/sampling/lnInclude -I/usr/lib/openfoam/openfoam2206/src/dynamicFvMesh/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels -I/usr/lib/openfoam/openfoam2206/src/transportModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/interfaceProperties/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/twoPhaseMixture/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/turbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/phaseIncompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2FoamGABC/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2FoamSampling2206/lnInclude -I/usr/include -DOFVERSION=2206 -DEXTBRANCH=0 -DOFPLUSBRANCH=1 -DXVERSION=0 -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2206/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2206/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/waveFoam.o -L/usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/lib \ -lfiniteVolume -lfvOptions -lmeshTools -lsampling -ldynamicFvMesh -lincompressibleTransportModels -linterfaceProperties -limmiscibleIncompressibleTwoPhaseMixture -ltwoPhaseProperties -lturbulenceModels -lincompressibleTurbulenceModels -lwaveModels -lVoFphaseTurbulentTransportModels -lincompressibleInterPhaseTransportModels -L/home/edoardoforte/OpenFOAM/edoardoforte-v2206/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamGABC -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam /usr/bin/ld: cannot open output file /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam: Permission denied collect2: error: ld returned 1 exit status make: *** [/usr/lib/openfoam/openfoam2206/wmake/makefiles/general:150: /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam] Error 1 The other solvers like porousWaveFoam seem to work properly. What could be the cause of the problem? I will attach folders with waves2foam Allwmake.log file and the standing wave log files. Thanks to anyone who is willing to help! |
February 19, 2024, 12:35 |
Solution
Marion Sant
Rep Power: 2 |
EDIT: For anyone who should face this problem.
Coding sudo chown -R "$USER:" /path/to/the/directory in the terminal before doing ./Allwmake should solve the problem |
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 84 | September 2, 2022 01:04 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
