Checkerboarding in LES
Old   June 10, 2009, 04:22
Default Checkerboarding in LES
Matteo Baldi
Matteo85 is on a distinguished road
I've been testing LES/DES models using the central differencing scheme for the convective term of the momentum equation, on some test-cases in which the flow encounters a bluff body (square cylinder; ribs in a channel). Despite adopting configurations and grids very similar to the ones employed in some works present in literature, the simulations I've been running suffer from the well-known problem of Checkerboarding, that presents itself in the velocity field (it persists even averaging in time) but not in the pressure field. It seems that OpenFoam with the central scheme is not able to provide a correct solution on grids that are used successfully in literature.
I'd like to know if any of you has experienced such difficulties in using the central difference scheme in OF.
Thank you very much,
Matteo
Matteo85 is offline   Reply With Quote
central scheme, checkerboard, convective term, des, les
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 3 September 15, 2012 22:15
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 0 June 9, 2009 09:47
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
