RhoTurbFoam max number of iterations
Old   February 11, 2009, 23:02
Default Hi, I'm using rhoTurbFoam to s
Jia Ming Kok
jia_kok is on a distinguished road
Hi, I'm using rhoTurbFoam to solve for supersonic flow. The solver works fine for mach number 1.0, but i get the error message that the max number of iterations is reached verytime i do something more than mach 1.0. I've attached the error message below.
--> FOAM FATAL ERROR : Maximum number of iterations exceeded#0 Foam::error::printStack(Foam:stream&) in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysica lModels.so"
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::correct() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysica lModels.so"
#4 main in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbF oam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbF oam"
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/specie/lnInclud e/specieThermoI.H at line 83.
FOAM aborting
Cheers
Jia
jia_kok is offline   Reply With Quote
Old   March 12, 2009, 05:21
Default Hia Jia, do you found the tri
Hamed Aghajani
haghajani is on a distinguished road
Hia Jia,
do you found the trick?
I faced this error in dieselFoam,
regards,
Hamed
haghajani is offline   Reply With Quote
Old   March 13, 2009, 05:43
Default Hi, I am also getting this
Kieran Wood
kieranwood85 is on a distinguished road
I am also getting this message when running rhoCentralFoam. My case has both subsonic and supersonic flow and seems to work fine but then always crashes with this error after a while.
Does any one know what it means?
Thanks
Kieran
kieranwood85 is offline   Reply With Quote
Old   April 17, 2009, 09:57
Angry Same Err
mehulkumar is on a distinguished road
Hi..friends.
I am solving one case using rhoTurbFoam but after few iteration it stops with the same error report as mentioned above.
I am not getting why this Err means.
What I understood is there may be sudden Temp raise found this is causing Err.
I am not sure.
I tried to verify BCs and discretization schemes also but got no idea about Err cause.
Pls..come forward and help to understand it.
Thanks
Mehulkumar
mehulkumar is offline   Reply With Quote
Old   June 29, 2009, 05:43
Post shantha
shanthakumar
shantha is on a distinguished road
hello friends,
i am facing some issues after 2 iter, please find attached log file
Maximum number of iteration exceeded#0 Foam ::error:rintStack(Foam::Ostream&) error.
please help me any body, i found error after 2 iterations
shantha is offline   Reply With Quote
Old   June 29, 2009, 05:48
shanthakumar
hi..jia_kok
Did you fix that issue? if it how did you do it?
i am facing same problem, please help me on the same
Old   July 3, 2009, 05:03
Rachel Vogl
Rachel is on a distinguished road
MOst probably your BC are wrong.
Look at rho !
Its too high !
That is leading to problem with time step continuity...
recheck your BC and how do you initialize your domain?
Rachel is offline   Reply With Quote
UDF and Number iterations neyugnteivgnuh FLUENT 2 June 14, 2021 07:17
number rof iterations predicted philippe FLUENT 0 May 7, 2003 03:56
maximum number of iterations solomon FLUENT 6 April 24, 2003 15:42
about number of iterations lingo FLUENT 8 July 2, 2002 04:36
number of iterations for convergence CHUBBY FLUENT 4 April 22, 2001 05:27
