Question about field defintion
Old   July 1, 2009, 10:12
Default Question about field defintion
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
I have a question concerning the definition of fields, either vectorial or tensorial, for CFD calculations. In
particular, during my calculations I have to calculate the gradient of velocity field, by defintion a volVectorField,
using the formula
DU = fvc :: grad (U);
Both DU and U are defined in the file createFields.H, in the following form
// Reading the velocity field
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Creating Velocity Gradient Tensorial Field\n" << endl;
volTensorField DU
IOobject
"DU",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
fvc::grad(U)
This way, I ensure that in each mesh point I calculate correctly DU, right?
Other form could be doing the following
volTensorField DU = fvc :: grad ( U() );
I believe the first form is correct, although the second may work. Can anybody help me out?
Regards,
Titio
titio is offline   Reply With Quote
Old   July 6, 2009, 06:39
Henrik Rusche
henrik is on a distinguished road
Dear Titio,
Both forms are possible and the second will work if you delete the brackets on U.
volTensorField DU = fvc::grad (U);
Henrik
henrik is offline   Reply With Quote
External magnetic field data Richard Lee FLUENT 7 January 11, 2019 04:43
Initial velocity field in StarCCM+ Subhadeep Siemens 3 December 21, 2008 03:40
rerun with same flow field, different fluid props Tim Phoenics 0 March 3, 2004 14:51
question K.L.Huang Siemens 1 March 29, 2000 04:57
Question concering about validating Temperature field ghlee Main CFD Forum 1 December 1, 1998 12:36
