TurbulentIntensityKineticEnergyInlet problem with turbulenceR |
January 2, 2008, 10:49 |
I am trying to use t
nicolas
Rep Power: 17 |
I am trying to use the turbulentIntensityKineticEnergyInlet boundary condition with the simpleFoam solver: my only problem occurs when i am computing viscous drag on a wall, i get the following error: --> FOAM FATAL ERROR : Unknown patchTypefield type turbulentIntensityKineticEnergyInlet Valid patchField types are : 25 ( fixedGradient symmetryPlane directMapped oscillatingFixedValue turbulentInlet freestream default empty fixedValue uniformFixedValue cyclic mixed processor calculated slip timeVaryingMappedFixedValue timeVaryingUniformFixedValue directionMixed sliced partialSlip outletInlet inletOutlet wedge zeroGradient waveTransmissive ) From function fvPatchField<type>::New(const word&, const fvPatch&, const Field<type>&) in file /home/nr/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/newFvPatchField.C at line 57. This occurs when using turbulence->R()().boundaryField()[patchLabel]. I am not trying to compute viscous drag at the inlet , so patchLabel is always a wall. I have looked though the turbulence source files, but i can't see what's missing. My current idea is that the boundary is not included in the turbulence library but i am not sure. Any help appreciated. Thanks, Nicolas |
June 20, 2008, 05:19 |
I also have the Turb
Markus Rehm
Rep Power: 17 |
I also have the TurbulentIntensityKineticEnergyInlet-BC and it works fine with the kEpsilon turbulence. Now I want to switch to RSM (LRR) model. For that I need the Reynolds stresses which I usually calculate with the tool "R". But it does not accept that BC. A similar error message as shown above. How could one modify R to recognize that BC? Or any other ideas? Regards Markus. |
July 6, 2009, 10:07 |
Same as in OF-1.5
Sumeet Kumar
Rep Power: 17 |
Hi All,
I am also receiving the similar error messages. I am trying the access the "R" Reynolds stresses from the standard turbulence models say for e.g. kEpsilon in my application. ------------------------------------------------------------------------------------------------------------ const volSymmTensorField& R = this->turbulence().R(); scalar uu = R[celli].xx(); // where uu is Rxx in cell "celli". ----------------------------------------------------------------------------------------------------------- However on running the application for a case, I received following fatal error :: Unknown patchTypefield type turbulentIntensityKineticEnergyInlet Valid patchField types are : 26 ( fixedGradient symmetryPlane directMapped oscillatingFixedValue turbulentInlet freestream empty fixedValue uniformFixedValue cyclic mixed processor calculated slip timeVaryingMappedFixedValue timeVaryingUniformFixedValue directionMixed generic sliced outletInlet partialSlip inletOutlet advective wedge zeroGradient waveTransmissive ) From function fvPatchField<Type>::New(const word&, const fvPatch&, const Dim ensionedField<Type, volMesh>&) in file lnInclude/newFvPatchField.C at line 54. FOAM exiting The "turbulentIntensityKineticEnergyInlet" BC for the 'k' field variable runs well with the OF turbulence models. However, it is not supported when I try to access the Reynolds Stresses. There is one more similar topic (http://www.cfd-online.com/Forums/ope...ergyinlet.html) but that was not answered. Please advice someone. Thanks |
TurbulentIntensityKineticEnergyInlet | r2d2 | OpenFOAM Running, Solving & CFD | 3 | September 19, 2009 03:56 |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
