OF distributed
Old   July 11, 2009, 06:21
Default OF distributed
BastiL
bastil is on a distinguished road
Dear all,
due to performence problems I am currently trying to use OF in distributed mode as described in the user guide. Does anybody know some numbers about how large speedup will be?
I managed to distribute data to scratch on all of the cluster nodes and run from there. Obvisously, the number of root paths in the decomposeParDict must be the same as the number of cores, even if all the nodes have the data at the same path?
I am unsure about what I need to copy back after the run? Since I copy all the processor* directories as well as system and constant (without polyMesh) to all nodes where are the results? Do I need to copy back all processor*s from all cpus? How do I know where the "correct" final solution for which processor is located in?
Thanks and regards
BastiL
bastil is offline   Reply With Quote
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
Distributed Parallel on dual core remote machine Justin CFX 1 February 3, 2008 17:23
Firewall settings bproc distributed file syntax mike_jaworski OpenFOAM 2 January 14, 2008 10:46
distributed mpich problem Trevor CFX 15 January 9, 2007 17:08
CFX distributed computing: Cluster design Q Joe CFX 7 July 11, 2006 10:21
