Error
Dear All,
At the time of solving rhoSimplefoam, I was getting following error. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : rhoSimpleFoam Date : Jul 21 2009 Time : 12:59:25 Host : bagvapp PID : 3213 Case : /home/bagside/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhoSimpleFoam/injectorthermal nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; alphah 1; alphak 1; alphaEps 0.76923; } Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.11968e-06, No Iterations 7 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.16559e-06, No Iterations 6 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.83583e-06, No Iterations 6 #0 Foam::error::printStack(Foam::Ostream&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0x110400] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam" #6 main in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam" #7 __libc_start_main in "/lib/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam" In the rhoSimpleFoam, I am solving injectionmixer thermal problem. Injectionmixer has two inlets. At Inlet1, air is entering at 10 m/s, 295 K and at Inlet2 air is entering at 0.1 m/s, 315K. In this Foam, I am using KEpslion turbulence model. Does anyone know what this error means? Thanks for any help! Best Regards, Sam |
