July 3, 2009, 09:05 |
Faces during change of topology in the mesh
Virginie Ehrlacher
Rep Power: 17 |
Hi Foamers,
I have a question about OpenFOAM and the mesh handling. I am trying to code an interTrackFoam solver which would keep the quality of the mesh above a certain level (typically, I use as an indicator the ratio of the inradius and the circumradius of the tetrahedra of the mesh and I do not allow it to be under a minimum value). So I coded functions which enables the cells of the mesh to check this criterion and when I look at the resulting mesh, everything seems fine: there is no irregularity or holes in the mesh and the process runs without any error message. However, when I perform this function, the calculus of U and p goes on a little while but quickly produce a time step continuity error. I think this is due to the fact that I did not correctly orient my faces: I read somewhere that an internal face should be such has neighbour label > owner label and such that the ordering of the points produce a normal which points into the neighbour cell (with the right-hand rule). Is there a way to set the orientation of the faces right automatically with the class directTopoChange? I saw variables such as flipFaceFlux... Is that it? Should I set this to true? Or have you got any idea of what this error could be due to? Thank you a lot in advance. Virginie |
July 11, 2009, 21:54 |
Sandeep Menon
Rep Power: 25 |
I'm quite sure that the error is due to a wrong flux value, and you're right - flipFaceFlux is used to reverse the face-flux if the face changed orientation due to a topo-change. However, you can choose to correct fluxes explicitly using an additional pressure Poisson equation - take a cue from icoDyMFoam, where a correctPhi.H is used.
It's up to you to decide whether the Poisson solution is warranted - it may or may not be a performance issue. For simple topo-changes, flipFaceFlux is a convenient way to maintain divergence-free fluxes, but more complicated situations might simply be too difficult to handle, and a Poisson solution is a more convenient solution (which I'm really not fond of). Hope this helps. |
August 13, 2009, 03:47 |
Virginie Ehrlacher
Rep Power: 17 |
Thank you very much Sandeep for your answer. It helped me indeed to solve the problems I had. I had though another question: I read somewhere that for a given face, the cell label of the neighbour cell should be greater than the label owner. What might happen if it is not the case? If i set the option cells renumbering true in the directTopoChange function update mesh, does it set cell labels so that this rule is respected?
Thank you a lot. Virginie |
August 15, 2009, 13:32 |
Sandeep Menon
Rep Power: 25 |
Yup. It's good to be consistent about owner-neighbour ordering, since this approach has the advantage of being able to assume (without a priori knowledge about the mesh) that face normals will point from owner to neighbour, and that face right-handedness defines that direction as well. The face-normal direction is fairly important while defining gradient/divergence operators, and I suspect that improper owner-neighbour numbering won't have an impact on solution results, but I haven't tested this. I think it would be easier to play safe and stick to the convention.
A cursory glance at the directTopoChange code suggests that the owner-neighbour ordering is taken care of during the re-ordering stage. I found this bit of code in directTopoChange.C: Code:
// Renumber owner/neighbour. Take into account if neighbour suddenly // gets lower cell than owner. forAll(faceOwner_, faceI) { label own = faceOwner_[faceI]; label nei = faceNeighbour_[faceI]; if (own >= 0) { // Update owner faceOwner_[faceI] = localCellMap[own]; if (nei >= 0) { // Update neighbour. faceNeighbour_[faceI] = localCellMap[nei]; // Check if face needs reversing. if ( faceNeighbour_[faceI] >= 0 && faceNeighbour_[faceI] < faceOwner_[faceI] ) { faces_[faceI] = faces_[faceI].reverseFace(); Swap(faceOwner_[faceI], faceNeighbour_[faceI]); } } } else if (nei >= 0) { // Update neighbour. faceNeighbour_[faceI] = localCellMap[nei]; } } |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
