Adding liftDrag to Openfoam141
Old   May 31, 2008, 22:46
Default Hello I have been trying to
srinath
srinath is on a distinguished road
Hello
I have been trying to add the liftdrag utility from OpenFoam-1.2 as per the post,
http://www.cfd-online.com/cgi-bin/Op...=8678#POST8678
The only change i have done is to use the latest dev version from
http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/
and cp -r the directory
/src/postProcessing to version 1.4.1/src/
I succesfully make the library
libincompressiblePostProcessing.so
My problem comes when i try to make the liftDrag binary
This is the error i get
srinath@dell:~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/miscellaneous/l iftDrag$ wclean && wmake
Making dependency list for source file liftDrag.C
SOURCE=liftDrag.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/postProcessing/incompressible/lnIncl ude -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/srinath/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/liftDrag.o
liftDrag.C: In function 'int main(int, char**)':
liftDrag.C:140: error: 'dragCoefficient' was not declared in this scope
liftDrag.C:150: error: 'liftCoefficient' was not declared in this scope
liftDrag.C:161: error: 'momentCoefficient' was not declared in this scope
make: *** [Make/linuxGccDPOpt/liftDrag.o] Error 1
Has anyone tried adding the liftDrag utility to 1.4.1?
Any help will be much appreciated
srinath is offline   Reply With Quote
Old   June 1, 2008, 15:34
Default I think you are missing liftDr
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I think you are missing liftDrag.H where those coefficients are defined. See if you can find a liftDrag.H file.
msrinath80 is offline   Reply With Quote
Old   June 1, 2008, 21:48
Default Hi Srinath I found that it
srinath
Hi Srinath
I found that it is picking up liftDrag.H. The problem was that liftDrag in version 1.4 is in a different namespace, so i did the following
I added the line
using namespace Foam::liftDrag to the liftDrag.C, found in /applications/utilities/postProcessing/miscellaneous/liftDrag$
It compiles then, but fails in the linking stage because it can't find libfoamUtil.so
A find command didn't locate such a library, so i assumed ver1.4 has done away with it and removed the line -lfoamUtils found in
/applications/utilities/postProcessing/miscellaneous/liftDrag/Make/options
Now everything compiles and links properly.
Unfortunately things don't seem to be as good as they seem.
When i go to FoamX and execute
foamUtilities->postProcessing->miscellaneous->liftDrag, i get the following error.(I am running it on icofoam/cavity)
Time = 0
Reading U
Reading p
Inlet velocity: (1 0 0)
#0 Foam::error::printStack(Foam:stream&) in "/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::liftDrag::momentCoefficient(Foam::GeometricF ield<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&) in "/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressiblePostPr ocessing.so"
#4 main in "/home/srinath/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/srinath/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag"
Am i executing the liftDrag command correctly? Does it need other options?
Thanks
Srinath
Old   June 1, 2008, 23:38
Default Hi there, If you search the
Hi there,
If you search the forum, you'll find that most of us who are interested in dimensionless force coefficients have picked out the required code from the liftDrag utility (Thanks to Frank Bos) and modified the solver (such as icoFoam) to calculate them and print them directly to the log file. I suggest that you do the same. Instructions for modifying the solver are available in some of the forum threads. Check this[1] thread for an example of the same using the turbFoam solver.
Of course, if this isn't a high priority at this point, you could always wait for OpenFOAM 1.5, which I believe will calculate lift and drag coefficients natively.
Hope this helps :-)
[1] http://www.cfd-online.com/OpenFOAM_D...es/1/5181.html
Old   June 2, 2008, 09:39
Default Hi Srinath Thanks for point
srinath
Hi Srinath
Thanks for pointing me to the link where you modified turbFoam, i will try to do the same with icoFoam.
Old   June 3, 2008, 11:32
Default I added the liftDrag utility t
Giovanni Caramia
karamiag is on a distinguished road
I added the liftDrag utility to 1.4.1, here there is what I have done:
1- From http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/
I downloaded the directory
src/postProcessing/incompressible/liftDrag
2- I copied it in
3- From
applications/utilities/postProcessing/wall/liftDrag
4- I copied it in
OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/wall
5- I went in
6- I executed
./Alwmake
7-I went in
OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/wall/liftDrag
8- I executed
wclean && wmake
I did not use liftDrag in FoamX but it seem to work if I use the command line.
Hope this helps
karamiag is offline   Reply With Quote
Old   August 24, 2009, 19:04
Default liftDrag OpenFOAM 1.6
John
nomad is on a distinguished road
Does anybody know the whereabouts of the liftDrag tool for OpenFoam v1.6?
Do I need to use the one from v1.2?
Thanks
nomad is offline   Reply With Quote
Old   August 24, 2009, 23:36
John
The liftDrag utility from v1.2 doesn't work with v1.6. I'm referring to the wclean && wmake in Step 7 of the trivial compile.
Old   August 25, 2009, 10:43
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Originally Posted by nomad View Post
Thanks
No, you don't need.
It is implemented inside the code. Look at:
http://www.cfd-online.com/Forums/ope...es-of15-7.html
Best Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   August 25, 2009, 13:39
John
Thanks Paulo.
Gentoo ebuild for OpenFOAM141 deepblue17 OpenFOAM Installation 3 July 29, 2010 09:27
OpenFoam141 problem after installation mateuszzb OpenFOAM Installation 1 July 2, 2008 04:11
[OpenFOAM] Read native OpenFoam141 with Paraview321 hjg911 ParaView 1 March 10, 2008 16:57
OpenFOAM141 installation problem on Itanium machine skabilan OpenFOAM Installation 3 February 6, 2008 09:05
Trying to install OpenFoam141 jam OpenFOAM Installation 5 December 22, 2007 11:16
