Error in turbulentHeatFluxTemperatureFvPatchScalarField v1.6
Old   September 16, 2009, 08:06
Default Error in turbulentHeatFluxTemperatureFvPatchScalarField v1.6
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
I noticed an error in turbulentHeatFluxTemperatureFvPatchScalarField class for temperature gradient calculation:
00146 void turbulentHeatFluxTemperatureFvPatchScalarField::updateCoeffs()
00147 {
00148     if (updated())
00149     {
00150         return;
00151     }
00152
00153     const scalarField& alphaEffp =
00154         patch().lookupPatchField<volScalarField, scalar>(alphaEffName_);
00155
00156     const scalarField& Cpp =
00157         patch().lookupPatchField<volScalarField, scalar>(CpName_);
00158
 00159     gradient() = q_/(Cpp*alphaEffp);
00160
00161     fixedGradientFvPatchScalarField::updateCoeffs();
00162 }
From my point of view and based on Fourier's law heat flux q is calculated as:
q = lambda * grad (T) = alpha * rho * Cp * grad (T)
where
lambda - thermal conductivity
alpha - thermal diffusivity
Cp - cpecific heat capacity
rho - density
Thus temperature gradient should be
grad (T) = q / (alpha * rho * Cp)
Please correct me if I'm wrong!
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   September 17, 2009, 02:36
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Are you speaking of the class in the "compressible" or in the "incompressible" namespace?
They are formulated somewhat differently and the incompressible formulation will obviously not have rho in it.
olesen is offline   Reply With Quote
Old   September 17, 2009, 03:32
Mark,
I'm speaking about incompressible namespace.
In any case, if not include density in heat flux calculations, left-hand and right-hand dimensions in that relationship will not meet! That is what I mean in details:
00053 class turbulentHeatFluxTemperatureFvPatchScalarField
00054 :
00055     public fixedGradientFvPatchScalarField
00056 {
00057 // Private data
00058
00059     //- Heat flux [W/m2]
00060     scalarField q_;
00061
00062     //- Name of effective thermal diffusivity field
00063     word alphaEffName_;
00064
00065     //- Name of specific heat capacity field
00066     word CpName_;
00067
[q]
= W / m^2 = (J / s) / m^2 = (kg m^2 / s^3) / m^2 = kg / s^3
[lambda] = W / (m K)= (kg m^2 / s^3) / (m K) = kg m / (K s^3)
[alpha = lambda / (rho Cp)] = m^2 / s
[Cp] = J / (kg K) = (kg m^2 / s^2 ) / (kg K) = m^2 / (K s^2)
[grad (T)] = K / m
Thus
q = lambda * grad (T) => [LHS] = W / m^2 equal to [RHS] = W / (m K) * K / m = W / m^2
But if we calculate grad (T) as q / (alpha Cp), then we get
grad (T) = q / (alpha Cp) => [LHS] = K / m not equal to! [RHS] = kg / s^3 / (m^2 / s * m^2 / (K s^2)) = kg K / m^4
So we see that dimensions of the left-hand side (LHS) and the right-hand side (RHS) do not meet unless other than traditional units are used for thermal conductivity, thermal diffusivity, specific heat capacity etc.
It is easy to check, that q = (alpha Cp rho ) grad (T) => grad (T) = q / (alpha Cp rho) gives correct result after dimensions analyzis.
Best regards,
Old   September 17, 2009, 09:54
Yi Wang
jason_wy is on a distinguished road
Not sure in incompressible solvers. But in compressible solvers, alphaEff and alpha defined in OF are not the same as the alpha [m^2/s] that we typically refer to.
They actually have already included rho in the definition. Basically in OpenFOAM: alpha = lambda/Cp ( not lambda/Cp/rho)
You might want to check the thermoPhysicalModel to find it out.
jason_wy is offline   Reply With Quote
Old   September 17, 2009, 10:28
Thank you, Yi!
Following your guidance I found in basicThermo_8H_source.html:
00077             //- Laminar thermal diffusuvity [kg/m/s]
00078             volScalarField alpha_;
That is why there was ambiguity.
Best regards,
Forces in V1.6 terrybarnaby OpenFOAM Post-Processing 72 September 2, 2015 16:49
installing v1.6 and keeping v1.5 Gavin OpenFOAM 9 October 23, 2009 04:16
nutRoughWallFunction v1.6 Schag OpenFOAM 2 October 1, 2009 16:28
icoDyMFoam v1.6 shyam OpenFOAM Bugs 1 September 5, 2009 04:22
Postprocessing and uniformDensityHydrostaticPressure in v1.6 Schag OpenFOAM Bugs 2 July 28, 2009 13:41
