InterFoam+ Surface tension dependent on temperature
Old   September 30, 2009, 13:44
Default InterFoam+ Surface tension dependent on temperature
Ramesh Yapalparvi
yapalparvi is on a distinguished road
I have been able to add energy equation to the interFoam solver and do some test cases with that and it works OK. In this case the surface tension was a constant. Now I would like to make it dependent on temperature. Any help?
Thanks
Ramesh
yapalparvi is offline   Reply With Quote
Old   October 1, 2009, 07:07
isabel
isabel is on a distinguished road
If you read the files "interfaceProperties.C" and "interfaceProperties.H" you will see how to set the surface tension, sigma, as temperature dependent.
isabel is offline   Reply With Quote
Old   October 27, 2009, 05:45
Alex Gatej
AlGates is on a distinguished road
Think, I have the same problem here. interfaceProperties reads the sigma-values in the constructor, but this happens only at the beginning of the simulation and the constructor is never called again.
Should there be added a new function to be able to change the values of sigma?
AlGates is offline   Reply With Quote
Old   October 27, 2009, 10:50
isabel
I have implemented this code:
volVectorField gradgamma = fvc::grad(gamma);
surfaceVectorField gradgammaf = fvc::interpolate(gradgamma);
surfaceVectorField nHatfv = gradgammaf/(mag(gradgammaf) + SMALL); // normal vector
surfaceScalarField nHatf_ = nHatfv & mesh.Sf();
volScalarField K_ = -fvc::div(nHatf_); //curvature
The momentum equation would change this line:
solve
UEqn
fvc::reconstruct
fvc::interpolate(sigma*K_)*fvc::snGrad(gamma)
- ghf*fvc::snGrad(rho)
- fvc::snGrad(pd)
) * mesh.magSf()
And the pressure equation would change this:
phi = phiU +
)*rUAf*mesh.magSf();
Old   July 30, 2012, 02:25
Default plz answer me???
vahid
vahid.najafi is an unknown quantity at this point
Hi Dear Isabel.
I want to add surface tension(sigma) in a code,for this added :
#include ''fvCFD.H''
#include ''interfaceproperties.H''
fvc::interpolate(interface.sigma())
in this code:
Foam::tmp<Foam::volScalarField>
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff
const volScalarField& p
) const
volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
volScalarField rho
limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2()
return
//......I want to change it( <<sigma>> surface tension multiple in it):
(3*rho1()*rho2())*sqrt(2/(3*rho1()))* (fvc::interpolate(interface.sigma()))
*rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat()));
dont successful wmake, and seen(was not declared ):
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: 'interface' was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
please help me,How to correct this problem???
vahid.najafi is offline   Reply With Quote
Old   August 1, 2012, 11:11
isabel
Dear vahid.najafi,
I am not sure which your the problem. Your solver should compile Ok (I am working with OpenFOAM 1.7 version). Try these ideas:
- Write "interfaceProperties.H" instead of "interfaceproperties.H"
- Add the line #include "twoPhaseMiture.H"
If these changes do not work do not hesitate to answer again
Old   August 2, 2012, 05:21
Default Thanks for your answer Isabel:
vahid
Hi Dear Isabel.
Thanks for your answer.
I worked what ,you said to me :
I Changed solver, As follows:
#include "fvCFD.H"
#include "twoPhaseMixture.H"
#include "interfaceProperties.H"
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::r Rb
const volScalarField& limitedAlpha1
) const
return pow
((4*constant::mathematical:i*n_)/3)*fvc::interpolate(interface.sigma())
*limitedAlpha1/(1.0 + alphaNuc() - limitedAlpha1),
1.0/3.0
but i seen again:
geTwoPhaseMixtures::SchnerrSauer::rRb(const Foam::volScalarField&) const’:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:83: error: 'interface' was not declared in this scope
an other question :
twoPhaseMixture.H in directury in src files:
transportModels/incompressible/incompressibleTwoPhaseMixture \
but sigma is not Definition in this code!!!
The directory above is correct???That is your purpose(for twoPhaseMiture.H)?
regards
Vahid Najafi
Old   February 19, 2016, 11:51
Rimsha
block is on a distinguished road
thanks found my problem
block is offline   Reply With Quote
Surface tension asder CFX 2 August 4, 2008 09:41
Surface Tension Gradient Alisher FLUENT 0 March 26, 2008 04:26
UDF for surface tension gradient kiran FLUENT 2 July 15, 2003 12:00
surface tension in VOF New1 FLUENT 0 April 10, 2002 01:06
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
