initial conditions
Old   November 25, 2009, 10:50
Default initial conditions
stephane sanchi
openfoam_user is on a distinguished road
Inside the /0 directory I have the initialConditions file with
sideslip 20;
velocityMagnitude 20;
pressure 0;
turbulentKE 0.24;
turbulentOmega 1.78;
#inputMode merge
I have the U file with :
#include "initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform ($velocityMagnitude*cos(sideslip) $velocityMagnitude*sin(sideslip) 0);
The last line (internalField uniform ...) is not valid.
Is it possible to write such an expression there ?
Regards,
Stephane
openfoam_user is offline   Reply With Quote
Old   November 26, 2009, 02:25
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
No, what you are trying isn't possible. The code would need an extra interpreter in the dictionary processing for that to work.
If you don't mind having two passes, you could write an "initialConditions.m4" and pass it through the m4 processor first to produce your "initialConditions" file.
If you look through the tutorials, you can see a few examples where m4+perl has been used to create blockMeshDict files.
Here's a quick way to find those examples:
git ls-files | grep .m4
olesen is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
