floating point exception
Old   March 7, 2014, 19:31
Default floating point exception
J. Brindley
oldirtybrindley is on a distinguished road
Not sure what's going on. Can't get simpleFoam to run
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.081410493, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.061596729, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.091684187, No Iterations 3
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0059667553, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.40650934, Final residual = 0.0012374181, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.036894522, Final residual = 0.00027957842, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.0062564286, Final residual = 4.8770264e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.0013606213, Final residual = 1.2695641e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.00035198339, Final residual = 3.117196e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.00010876533, Final residual = 1.0124916e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 3.7107364e-05, Final residual = 3.2700493e-07, No Iterations 3
GAMG:  Solving for p, Initial residual = 1.4011258e-05, Final residual = 1.2603484e-07, No Iterations 3
GAMG:  Solving for p, Initial residual = 5.5796704e-06, Final residual = 3.7850784e-08, No Iterations 6
GAMG:  Solving for p, Initial residual = 2.3340101e-06, Final residual = 6.442118e+119, No Iterations 1000
time step continuity errors : sum local = 1.2632859e+123, global = 4.4873194e+101, cumulative = 4.4873194e+101
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
#9  Foam::incompressible::RASModels::kOmegaSST::correct() at ??:?
 at ??:?
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
 at ??:?
Floating point exception (core dumped)
oldirtybrindley is offline   Reply With Quote
Old   March 7, 2014, 20:06
J. Brindley
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : checkMesh
Date   : Mar 07 2014
Time   : 20:04:09
Host   : "AVA-411296"
PID    : 26818
Case   : /home/kathyb/OpenFOAM/kathyb-2.3.0/run/SplitTipTesting/AOA/simplesolvefixed(donotuse)
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            72559
    internal faces:   60772
    cells:            21783
    faces per cell:   6.1208741
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     15749
    prisms:        1429
    wedges:        0
    pyramids:      0
    tet wedges:    128
    tetrahedra:    2
    polyhedra:     4475
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   1186
            5   814
            6   740
            7   218
            8   90
            9   678
           10   86
           11   47
           12   401
           13   3
           14   6
           15   150
           18   56
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
                   inlet        0        0                        ok (empty)
                  outlet        0        0                        ok (empty)
                   walls       40       67  ok (non-closed singly connected)
               frontBack        0        0                        ok (empty)
                    Foil    11747    13554  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.020220271 -0.010812593 -0.00023150215) (0.020260984 0.010818352 0.15183358)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-5.8212676e-17 4.5742309e-17 1.775036e-17) OK.
    Max cell openness = 2.9738872e-16 OK.
    Max aspect ratio = 21.38308 OK.
    Minimum face area = 6.6009305e-09. Maximum face area = 1.3716404e-05.  Face area magnitudes OK.
    Min volume = 1.1250083e-12. Max volume = 2.2923998e-08.  Total volume = 2.8560307e-05.  Cell volumes OK.
    Mesh non-orthogonality Max: 62.160689 average: 13.151348
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.6576963 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
|  \\    /   O peration     | Version:  2.2.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        0.02;
        relTol           0;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
    U
        solver           PBiCG;
	preconditioner	 DILU;
        tolerance        1e-6;
        relTol		0.1;
    k
        solver           PBiCG;
        tolerance        1e-6;
        relTol		0.1;
    omega
                solver           PBiCG;
        tolerance        1e-6;
        relTol		0.1;
	cellDisplacement
	solver	GAMG;
	tolerance	1e-5;
	relTol		0;
	smoother	GaussSeridel;
	cacheAgglomeration	true;
	nCellsInCoursestLevel	10;
	mergeLevels	1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pReffCell 0;
    pRefValue 0;
    residualControl
        p 1e-4;
	U 1e-4;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        omega           0.7;
cache
    grad(U);
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)	    Gauss linear;
    grad(k)    	    cellLimited Gauss linear 1;
    grad(omega)    	    cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;;
    div(phi,k)      bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited corrected 0.5;
    laplacian(DomegaEff,omega)		Gauss linear limited 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 0.33;
fluxRequired
    default         no;
    p;
Old   March 8, 2014, 16:56
Lieven
Lieven will become famous soon enough
Hi olddirtybrindly,
Do you get the same crash when you run the case with pisofoam?
Cheers,
L
Lieven is offline   Reply With Quote
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
