Negative Total Pressure in cavitatingFoam RAS/Throttle Case in OF 1.6 |
August 30, 2010, 15:59 |
Michael Ahlmann
Rep Power: 16 |
I'm working on modelling cavitating flow in a series of control valves, and my plan was to use cavitatingFoam to do so. However, when running the "Throttle" tutorial case in the "RAS" subfolder, I noticed that the total pressures (calculated using ptot utility) go negative which seems unphysical. I know that in some other CFD solvers there is a reference pressure somewhere, does OpenFOAM use anything similar? If not, can somebody explain why the negative pressure shows up?
September 6, 2010, 05:36 |
same problem...
I need to simulate the cavitation in an injector. To get more familiar with the code dedicated to the cavitation in openFoam, I try to run the throttle tutorials case.
I also got some negative value for the pressure. Moreover I can observe some backflow from the outlet and a kind of pressure wave... I donīt know how to solve the problem. If you have any idea, would be great! thx |
cavitatingfoam, multiphase, negative pressure, negative total pressure |
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 08:55 |
negative static pressure | Selo melo | FLUENT | 5 | December 18, 2006 09:30 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
