February 26, 2010, 07:06 |
Underexpanded Jets - code crash - Help
sankarv
Hello OpenFoamers
I need some help with the boundary conditions desperately. As I have mentioned in my previous post, I am trying to simulate an under-expanded jet. I have successfully simulated the same problem using Fluent. Now I am trying to use OpenFoam to compare the two solvers. (BTW, This is my first ever OpenFoam simulation.....) I am using rhoCentralFoam. It is a 2D grid I imported from Fluent using fluentMeshtoFoam. Here is the configuration. _________________________________ | free-stream | | | | wall_inlet | | |Outflow | | ! | ! jet_inlet axis | !-------------------------------------| Here is my 'p' file dimensions [1 -1 -2 0 0 0 0]; internalField uniform 10000.0; boundaryField { Jet_inlet { type totalPressure; value uniform 300000.0; p0 uniform 300000.0; U U; phi phi; rho none; psi psi; gamma 1.4; } wall_inlet { type zeroGradient; } axis { type zeroGradient; } outflow { type pressureTransmissive; value 10000.0 } top_boundary { type pressureTransmissive; value 10000.0 } } // ************************************************** *********************** // For the outflow and top_boundary (freestream) I have tried wave transmissive, zeroGradient,pressureTransmissive boundary conditions. But the simulation always crashes when the initial transient shock reaches the outflow. Here is my 'U' file dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Jet_inlet { type fixedValue; value uniform (319.2 0 0); } wall_inlet { type fixedValue; value uniform (0 0 0); } axis { type zeroGradient; } outflow { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } top_boundary { type zeroGradient; } } Here is my 'T' file { Jet_inlet { type totalTemperature; value uniform 300; T0 uniform 300; U U; phi phi; rho none; psi psi; gamma 1.4; } wall_inlet { type zeroGradient; } axis { type zeroGradient; } outflow { type zeroGradient; } top_boundary { type totalTemperature; value uniform 300; T0 uniform 300; U U; phi phi; rho none; psi psi; gamma 1.4; } } For the outflow and top_boundary (freestream) I have tried wave transmissive, zeroGradient,pressureTransmissive boundary conditions for pressure. But the simulation always crashes when the initial transient shock reaches the outflow. I must admit I am using the boundary conditions by looking at similar files in the rhoCentralFoam. I would sincerely appreciate if someone can tell me what is wrong with my set-up and also if possible tell me the meaning of the various keywords in the b.c files 'p','U' and 'T'. I can make an educated guess about some of them, but I would be more comfortable hearing that from experts out there... Please help Thanks Vaidya |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
From 2D compressible code to 3D code | David Liu | Main CFD Forum | 22 | June 26, 2012 17:59 |
Modelling underexpanded supersonic gas jets | Nandu | FLUENT | 0 | January 7, 2004 06:56 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
