How to use mesh modifiers
Like Tree2Likes
  • 1 Post By tehache
  • 1 Post By WiWo
Old   May 15, 2007, 06:29
Default Hi there, I managed to set
Thomas Jung
tehache is on a distinguished road
Hi there,
I managed to set up a moving (i.e. shrinking) mesh, and calculate some diffusion on it, seems to work fine.
Now I would like to use the layer addition/removal stuff. Have been searching a lot on forum and wiki - but have to admit I could not get an idea how to use mesh modifiers. Also, there seems not to be any tutorial really using layer removal.
What I tried:
added this to my dynamicFvMeshDict:
bottom
type layerAdditionRemoval;
faceZoneName bottomFaces;
minLayerThickness 5e-3;
maxLayerThickness 1e-2;
oldLayerThickness -1;
active on;
where bottom is a patch adjacent to which I would like to remove layers.
Apart from this, I am just calling mesh.upgrade() in my application.
However, somethings missing - nothing happens
(well, the mesh moves as before and as expected, but no layers are removed...)
Maybe I somehow have to create that facezone - but have no idea how...
Any hints?
Thank you!
Thomas
Zhiheng Wang likes this.
tehache is offline   Reply With Quote
Old   May 18, 2007, 04:27
Default o.k. .... found and compiled t
Thomas Jung
o.k. .... found and compiled the utility "setSet", and can construct faceSets now. However I am in doubt if a faceSet is the same as a faceZone ... could someone help me, please?
Thanks!
Thomas
Old   February 9, 2009, 05:09
Default Hallo Thomas i am at the sa
patrick riemer
patriem is on a distinguished road
Hallo Thomas
i am at the same point right now. I have a moving mesh with an oscillating plate. This patch is a wall, called plate. My mesh is deforming too much, so i need layer addition/removal.
It's important for me to solve that problem soon because i have to finish a thesis work.
I would be very thankful for some help.
I use 1.4.1-dev
- Do i need a file called meshModifiers in /constant? How do i introduce such faces rightExtrusionFace and leftExtrusionFace? What are they for?
- In the dynamicMeshDict:
How do i recompile movingConeTopoFvMesh.C for the case that i need another motion.
Desired function: u = dx/dt = VelAmplitude * cos(2*pi*freq*t) = VelAmp * cos(pi*t/VelPeriod)
In movingConeTopoFvMesh.C:
VelAmplitude * sin(t*pi/VelPeriod)
patriem is offline   Reply With Quote
Old   February 20, 2009, 05:36
Default Hello, I would need the same
Virginie Ehrlacher
virginie_e is on a distinguished road
I would need the same kind of advice: how do we use the meshModifiers? I have added a meshModifier file in constant/polymesh, however teh solver does not seem to take it into account.
Do I need another line of code to have it understand that I want the meshmodifier to be used?
I am using the last version of OpenFOAM-1.5-dev (on svn) and I am working with the solver InterTrackFoam to simulate the flow of a viscous liquid over a slope.
Thank you in advance.
Virginie
virginie_e is offline   Reply With Quote
Old   February 20, 2009, 06:24
Default You will need to write your ow
Hrvoje Jasak
You will need to write your own topoChangerFvMesh class, which will incorporate mesh motion and mesh modifiers. There's plenty of examples in the library.
Hrv
Hrvoje Jasak
Old   March 31, 2010, 05:22
Wolfgang W.
WiWo is on a distinguished road
Hello to you all,
I was wondering if one of you has had success in implementing a new topoChangerFvMesh class - especially with regard to merging layerAdditionRemoval and dynamic mesh motion.
I'm working on a problem which seems to resemble the one Patrick described very closely - I just use an expanding circular membrane instead of a plate.
I'm playing around with the movingConeTopoFvMesh class at the moment, trying to figure out how I can adapt it to my problem. Still, I fear that for a recently started OpenFOAM rookie it might be difficult to fight through all this without advice - especially with regard to including the mesh motion as well.
I would very much appreciate if anyone could point me to helpful examples of similar topoChangerFvMesh classes, provide some code fragments or any other advice.
Best regards,
Wolfgang
WiWo is offline   Reply With Quote
Create fine mesh that grows to coarse mesh (Urgent CZ FLUENT 1 January 3, 2009 10:36
Mesh motion independent mesh regions philippose OpenFOAM Running, Solving & CFD 12 August 5, 2008 16:16
Oscillatory mesh motion setup mesh flux ERROR jaswi OpenFOAM Running, Solving & CFD 5 August 23, 2007 04:41
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 04:11
