April 14, 2010, 23:50 |
ScalarTransportFoam
Senthil Kabilan
Rep Power: 17 |
Hi All,
I have a simple question regarding scalarTransportFoam. The code seems to be executing well, but out of the blues, the residual increases (see Time=0.08628 and Time=0.08629) and the starts to settle down. Do you think it has something to do with the way I have setup the problem? Time = 0.08622 DILUPBiCG: Solving for T, Initial residual = 3.20318e-05, Final residual = 2.31572e-11, No Iterations 8 Time = 0.08623 DILUPBiCG: Solving for T, Initial residual = 3.20261e-05, Final residual = 1.51511e-10, No Iterations 7 Time = 0.08624 DILUPBiCG: Solving for T, Initial residual = 3.20143e-05, Final residual = 6.6284e-11, No Iterations 8 Time = 0.08625 DILUPBiCG: Solving for T, Initial residual = 3.20118e-05, Final residual = 2.23166e-10, No Iterations 7 Time = 0.08626 DILUPBiCG: Solving for T, Initial residual = 3.20021e-05, Final residual = 8.8872e-11, No Iterations 8 Time = 0.08627 DILUPBiCG: Solving for T, Initial residual = 3.20002e-05, Final residual = 9.56583e-10, No Iterations 5 Time = 0.08628 DILUPBiCG: Solving for T, Initial residual = 3.19916e-05, Final residual = 8897.06, No Iterations 1001 Time = 0.08629 DILUPBiCG: Solving for T, Initial residual = 0.340886, Final residual = 9.89072e-10, No Iterations 19 Time = 0.0863 DILUPBiCG: Solving for T, Initial residual = 0.170177, Final residual = 1.99834e-10, No Iterations 20 Time = 0.08631 DILUPBiCG: Solving for T, Initial residual = 0.132551, Final residual = 1.36749e-10, No Iterations 21 Time = 0.08632 DILUPBiCG: Solving for T, Initial residual = 0.112358, Final residual = 2.48292e-10, No Iterations 19 Time = 0.08633 DILUPBiCG: Solving for T, Initial residual = 0.0994847, Final residual = 7.72147e-10, No Iterations 18 Time = 0.08634 DILUPBiCG: Solving for T, Initial residual = 0.0891127, Final residual = 5.79845e-10, No Iterations 18 Time = 0.08635 DILUPBiCG: Solving for T, Initial residual = 0.0806057, Final residual = 1.00459e-10, No Iterations 19 Thanks All Senthil |
April 15, 2010, 01:55 |
Alberto Passalacqua
Rep Power: 36 |
Hello. We cannot answer without knowing what problem you are solving.
Judging from the residuals something happens at Time = 0.08628, where the final residual is huge (8897.06 !) and the equation reaches the maximum number of iterations. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 15, 2010, 12:34 |
Senthil Kabilan
Rep Power: 17 |
Hi Alberto,
I am using scalarTransportFoam to to simulate diffusion of the acrolein through the rat respiratory system. The mesh is an all tetrahedral mesh with ~13 million elements. The U file in /0 is from a steady state simulation at a constant flow rate. Please let me know if you need further information. Thanks Senthil Below is T file. out1 { type zeroGradient; } out2 { type zeroGradient; } out3 { type zeroGradient; } out4 { type zeroGradient; } inlet { type fixedValue; value uniform 1.38e-06; } Wall { type fixedGradient; gradient uniform 0; } fvSolution file: solvers { T PBiCG { preconditioner DILU; tolerance 1e-09; relTol 0; }; } SIMPLE { nNonOrthogonalCorrectors 0; } |
April 15, 2010, 13:28 |
Alberto Passalacqua
Rep Power: 36 |
Just a couple of general hints.
You could check the mesh quality with checkMesh and see if there are very skewed cells. You could also try to perform 1-2 non-orthogonal correctors. Best,
Display Modes | |
ScalarTransportFoam for RTD calculations | santoo_cfd | OpenFOAM Running, Solving & CFD | 39 | July 12, 2021 02:15 |
ScalarTransportFoam and turbulent diffusion coefficient | rybakov2 | OpenFOAM Running, Solving & CFD | 2 | June 24, 2014 15:21 |
Problem with scalarTransportFoam illistrated using pitzDaily tutorial | mlawson | OpenFOAM | 2 | January 18, 2011 14:39 |
Modified scalarTransportFoam, but result is not right , need help | panda60 | OpenFOAM | 2 | December 2, 2009 20:50 |
flux seems not conserved in my modified scalarTransportFoam | danielr | OpenFOAM Running, Solving & CFD | 3 | October 5, 2009 17:05 |
