Apply wallfunction in LES
Hello Guys,
I want to apply a wall function to a wall in my LES simulation. After consulting the User Guide the boundaryField part of my 0/nuSgs file looks like this: boundaryField { top { type zeroGradient; } bottom { type nuSgsWallFunction; value uniform 1; } p1 { type cyclic; } p2 { type cyclic; } } Testing this with pisoFoam and oneEqEddy SGS Model the solver runs. If I now change the nuSgsWallFunction to e.g. "bla" nothing happens, the solver is still running without any problems. Furthermore if I apply my own wallFunction (change nuSgsWallFunction to moninObukhovWallFunction) where I added: Info << "Wall function is working " << endl; to the evaluate subroutine the solver still runs without any problems but I do not see the Info text on my screen which leads my to the assumption my wallFunction is not used. Have I forgot something to enable? Or is there a bug? kind regards, Fabian |
Allright I dont know why, but after hours of trying it works now ... :confused:
I also have met the same problem. So I don't know if the solver is using the wallFunction or not.
I tested this a little bit and this is not only a problem for wall functions. OpenFoam don't check if the type of boundary condition is valid. Even if you misspelled the type but you have set a value OpenFoam assumes a fixedValue type BC as default and do not inform you about your mistake. This is not a bug, but it would be good to give a hint to the user if using default.
