difference between 2.1.0 and 2.1.1 run.?
Old   February 13, 2013, 06:39
Default difference between 2.1.0 and 2.1.1 run.?
immortality's Avatar
Ehsan
immortality is on a distinguished road
although the run in openfoam 2.1.0 starts and after 500 iterations diverges.in 2.1.1 it doesn't start at all and shows an error:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : sonicFoam
Date   : Feb 13 2013
Time   : 15:04:08
Host   : "Ehsan-com"
PID    : 7412
Case   : /home/ehsan/Desktop/My_WR_sonicFoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4  Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5  Foam::basicPsiThermo::addfvMeshConstructorToTable<Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6  Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/sonicFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
Killing PID 7410
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 7410 was already dead
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/7410/status'
ehsan@Ehsan-com:~/Desktop/My_WR_sonicFoam$
my groovyBC is latest version.0.2.1 as funkySetFields verifies too at both openfoam versions.
immortality is offline   Reply With Quote
Old   February 14, 2013, 16:05
Ehsan
any opinion or thought?
Old   February 26, 2013, 18:17
Ehsan
has had someone similar experience or any idea related?
Old   February 27, 2013, 10:44
Retired Super Moderator
Bruno Santos
Hi Ehsan,
I'll quote myself from another thread on a nearly identical topic:
Originally Posted by wyldckat View Post
Not much information you're giving us. All that can be seen from this is that:
This implies that something is improperly defined, such as temperature set at 0 Kelvin, or pressure defined at 0 Pa... or something else.
Additionally, since you're comparing 2.1.0 with 2.1.1, then something was either fixed or broken in the mean time.
And without having access to at least a simple test case, then it only makes it harder to figure out what changed.
Best regards,
Bruno
Add temperature to icoFoam in OpenFOAM 2.1.1 magnounibo OpenFOAM Programming & Development 12 February 17, 2020 05:28
[OpenFOAM.org] OpenFOAM 2.1.1 installation on openSUSE 12.2 32 bit saturn_53 OpenFOAM Installation 13 February 1, 2015 04:17
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 11:46
New USer of OpenFOAM: How to run tutorials novice OpenFOAM 3 September 26, 2012 09:03
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
