minimum formulation in function calcUTau (S-A wall function)
Old   May 8, 2010, 19:21
Default minimum formulation in function calcUTau (S-A wall function)
Luise is on a distinguished road
I took a closer look at nutSpalartAllmarasWallFunction.C. In function calcUTau the calculation of kUu reads
kUu = min(50, kappa*Up/ut)
Why is this minimum formulation introduced here and why is it restricting to the particular value of 50?
Maybe it should keep the argument of the taylor expansion in a converging range, but 50 seems much too large for this. Does anybody have an idea?
Thanks in advance,
Luise
Luise is offline   Reply With Quote
Old   May 11, 2010, 03:38
Nobody knows anything?
In my calculations (a simple airfoil at 5deg incidence) the velocity profiles (sampled on the suction side at x/chord={0.07, 0.17, 0.3}) in the boundary layer show a strange behaviour, which seems to be a rather systematic problem:
For the cell closest to the wall the yPlus/uPlus mark is glued to the viscous sublayer, i.e. uPlus=yPlus.
Now, the Newtons method for finding the zero of f(uTau) is a gradient based method, while the function f shows a hyperbolic behaviour. So it might be better to engage other methods, which do not use gradients.
Otherwise, if all this has its reasons in some other part of the wallfunction or whatever (maybe the restriction of kUu), working on this would be a waste of time.
Thats what I figured!
Maybe someone knows better? I'm looking forward for suggestions!
Regards,
Luise
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
wall function Alex CFX 9 May 19, 2005 10:05
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
