September 6, 2011, 12:18 |
simpleFoam symbol lookup error
#1 | |
I'mworking with openFoam installed on ubuntu. The case i'm working on is an altered version of the motorBike tutorial. I've made my own mesh in Salome and i've edited motorBike to use mine. Four days ago, i successfully ran simpleFoam. I had to change all the patchnames and remove references to the motorbike.stl and all that but it worked.
Today, i tried to do the same with a finer mesh. The first one was very coarse, just a test to see if i could get it solved. I copied the previous case folder, replaced the Mesh_1.unv with the new one, did ideasUnvToFoam and made the boundary changes (patch type to wall) where needed just as i had done for the coarse mesh. But now it gives the following error: Quote:
September 6, 2011, 13:55 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
says the missing symbol is Foam::LESdelta::destroydictionaryConstructorTables () which should be in one of the LES-libraries (nothing about your case can change that). Is it possible that in the meantime parts of your OF-installation got updated/recompiled? Try other solvers that use turbulence |
September 6, 2011, 14:59 |
I didnt update Ubuntu itself or any installed progam. It is possible that it is sneakily updating without telling me through automatic updates in the background, but nothing that i've seen or asked for.
Would reinstalling openFoam fix it? |
September 6, 2011, 15:07 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The main suspect would have been an update of OF. Ubuntu-updates shouldn't trigger THAT kind of behaviour
Honestly: don't know. Did you compile it yourself or use binary packages? |
error, openfoam, simplefoam, symbol |
Display Modes | |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 21:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 07:12 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
