Second order upwinding scheme in OpenFoam
I followed the instructions given in the userguide to run the tutorial problem(lid driven cavity flow) using a linearupwind(after modifiying the actual linear scheme for interpolation) scheme but the run gets killed with the following message "attempt to read beyond EOF". Can anyone let me know what this means and help me to implement the second order upwind scheme. |
Hi there,
The following should work: Code:
div(phi,U) Gauss linearUpwind Gauss; Jose Santos |
hello !
is there a difference between "Gauss linearUpwind Gauss" and "Gauss linearUpwind Gauss linear" ? do you know how it works ? thanks a lot ! Marine |
Gauss linearUpwind Gauss does not work...
I believe the correct syntax is
Gauss linearUpwind phi |
