May 13, 2010, 06:11 |
Second order upwinding scheme in OpenFoam
subash
I followed the instructions given in the userguide to run the tutorial problem(lid driven cavity flow) using a linearupwind(after modifiying the actual linear scheme for interpolation) scheme but the run gets killed with the following message "attempt to read beyond EOF". Can anyone let me know what this means and help me to implement the second order upwind scheme. |
May 13, 2010, 16:10 |
Hi there,
The following should work: Code:
div(phi,U) Gauss linearUpwind Gauss; Jose Santos |
June 14, 2010, 10:30 |
Marine
hello !
is there a difference between "Gauss linearUpwind Gauss" and "Gauss linearUpwind Gauss linear" ? do you know how it works ? thanks a lot ! Marine |
June 20, 2012, 07:49 |
Rui Vizinho de Oliveira
Gauss linearUpwind Gauss does not work...
June 20, 2012, 18:28 |
Kyle Mooney
I believe the correct syntax is
Gauss linearUpwind phi |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
Godunov scheme | Peter | Main CFD Forum | 6 | November 27, 2009 10:51 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Choice of Upwinding Technique | paul | FLUENT | 1 | January 30, 2005 09:28 |
second order FD upwind scheme | Heinz Wilkening | Main CFD Forum | 2 | November 3, 1998 14:33 |
