Apply velocity dependent energy source to rhoSimpleFoam |
September 28, 2017, 13:09 |
Marco Nicotra
Dear All,
I would need your help to sort out this problem. I need to simulate the flow through a porous heat exhanger (cellZone) with rhoSimpleFoam. I would like to add a source term (only to this cellZone) to the energy equation (field h) so that depends on the local velocity magnitude. Specific power [W/m3] = knowValue *magU I tried to use scalarCodedSource in fvOptions but I couldn't make it to work because I'm running on a cluster and the run time compilation of the library doesn't seem to be supported (I got this error: Cannot read (NFS mounted) library). Does anybody can help me out with this? I would really appreciate any help. Best regards Marco |
December 21, 2017, 12:04 |
Taher Chegini
Rep Power: 12 |
I had this issue and by setting fileModificationChecking in $FOAM_ETC/controlDict to inotifyMaster, the problem was resolved.
energy equation, openfoam, rhosimplefoam, source |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
time dependent energy source term | kevinz | FLUENT | 0 | December 12, 2011 16:45 |
