MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed
Old   May 28, 2010, 11:15
Question MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed
bengt is on a distinguished road
Dear Foamers,
I've modified the mixerVessel2D in order to simulate a rotating shaft (cylinder) within a circular housing using MRFInterFoam. The housing is filled with oil up to the centre (fluid fraction 50%), and, accordingly, gravity is set to the -y direction.
The problem I'm facing now is that I can't get the solver running due to the following error: FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow.
Without gravity or with gravity acting in -z-direction (parallel to the rotational axis), there is no problem. Boundary conditions are set according to the tutorial case. Changing the pressure bc to buoyantPressure doesn't have any effect.
What am I doing wrong???
Any ideas or help are greatly appreciated!!
Kind regards, have a nice weekend
Bengt
bengt is offline   Reply With Quote
Old   May 28, 2010, 14:23
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
i suggest change mesh size or time step , some times its helpful.
nimasam is offline   Reply With Quote
Old   May 28, 2010, 14:45
Default problem persists
Hi nima,
thanks a lot for your reply!! Indeed, reducing the timestep/maxCo gets the solver working with the fluid fraction remaining constant - however, after 2 seconds it crashes giving the same error message...do you have any recommendations regarding the boundary conditions and discretization schemes / solver controls for such a case?
Kind regards
bengt
continuity error, gravity, mrfinterfoam
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
