combination of dynamicRefine and motionSolver
Old   November 24, 2009, 09:09
Default combination of dynamicRefine and motionSolver
bfa
Björn Fabritius
bfa is on a distinguished road
Hello all,
I tried to combine the motionSolverFvMesh (in OF-1.6) with the dynamicRefineFvMesh and solve using interDyMFoam.
I couldn't run my case with motion and refinement in a single step, so I changed the update() method such, that it does a refinement step based on the refineInterval value in dynamicMeshDict and a motion step otherwise. So a value of 2 would lead to alternately doing motion - refinement - motion - refinement etc.
The problem is: The first refinement step after any number of movements produces alpha1 values of 300 and larger and the solver crashes immediately. Both procedures seperately work fine, i.e. I can do the complete run with motion and without refinement, or I can run it doing refinement in every step without motion. But the combination does not work!
Has anyone ever tried a similar thing and succeeded? Any hints appreciated.
Regards,
Bjoern
bfa is offline   Reply With Quote
Old   January 12, 2010, 06:58
Wolfgang W.
WiWo is on a distinguished road
Dear Bjoern,
I was just about to pose the exacte same question as I'm also trying to implement mesh motion (dynamicMotionSolverFvMesh) and refinement (dynamicRefineFvMesh) into one procedure. It seems I didn't even get as far as you did ... I tried to write everything into dynamicMeshDict - didn't work of course because then I have two different assignements to dynamicFvMesh.
How did you do it? I'm working with dev-1.5 and a modified version of the icoFsiFoam solver at the moment.
Did you get any further with respect to this issue?
Best regards,
Wolfgang
WiWo is offline   Reply With Quote
Old   June 30, 2010, 11:54
yannH
yannH is on a distinguished road
I'm trying to use dynamic meshing and I want to know if someone has examples or documentation on dynamicMeshDict, others than tutorial ones, using dynamicMotionSolverFvMesh or dynamicRefineFvMesh or staticFvMesh, with the appropriate keywords...
Thanks
yannH is offline   Reply With Quote
dynamicrefine, interdymfoam
