problem with nonNewtonianIcoFoam
Old   July 16, 2010, 16:55
Default problem with nonNewtonianIcoFoam
Muhammad reza hassani
mhassani is on a distinguished road
hi
I wanted to solve a problem of a non-Newtonian fluid through an expansion of a 2D tube. I set a timeVaryingInletOutlet for velocity at the inlet and a time series for pressure at the outlet using timeVaryingFixedValue. viscosity model is BirdCarreau. I do not know what the problem is but the thing printed in the terminal is:
Courant Number mean: 0 max: 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 6.02929e-07, No Iterations 19
DILUPBiCG: Solving for Uy, Initial residual = 0.999937, Final residual = 7.89022e-07, No Iterations 19
DICPCG: Solving for p, Initial residual = 1, Final residual = 4.95431e-07, No Iterations 210
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#5 Foam::fv::correctedSnGrad<double>::correction(Foam ::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#7 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
in "/opt/openfoam170/applications/bin/linuxGccDPOpt/nonNewtonianIcoFoam"
#11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#12
Floating point exception
anyone knows how I can fix the problem?
mhassani is offline   Reply With Quote
Old   July 17, 2010, 05:49
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
first run ur solver with a simple model then add the complexity to it!!!!!!
these error can be made with various kind of mistakes from BC to solver, so its ambiguous!!!
nimasam is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 11:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
